Results 1 to 3 of 3
Thread: Interferance and non interferance
    Mar 2008
    Default Interferance and non interferance
    Ok i've been told that i can use 4agze pistons in my 20v.
    but it'll make the motor an interferance motor.?
    if this is the case then what are the pros and cons of changing this?
    Default Re: Interferance and non interferance
    Assuming you're using the ZE pistons because of turbo application, you'll be able to run more boost safely. ZE pistons will lower CR and are stronger..
    You've got to make sure the timing is set correctly before starting the car up otherwise your valves and pistons will kiss. Snapping a belt will also result in the piston meeting the valves. I honestly don't see a problem in this as long as you know for sure the timing is set correctly. Many motors are built as an interference motor from factory.
    oregon
    Arias carries low comp/boost capable 20V slugs....
    http://www.ariaspistons.com/ARIAS_2009_CAT.pdf
