Results 1 to 13 of 13
Thread: water/coolant leak in 18rg
    Junior Member 1st year Apprentice sexybackra28's Avatar
    Apr 2008
    Default water/coolant leak in 18rg
    there is a water/coolant leak in my 18rg i ve sussed it out and noticed none of my hoses are wet and i presume it is my water pump
    any advice would be great cheers guys
    Default Re: water/coolant leak in 18rg
    hey dood,
    Can you see the water leak on the ground? (Or do you have to keep topping it up).
    Park car over a clean bit of concrete and see if there are any leaks to confirm its an external leak.
    Also check the welsh plugs on the block. You should see a tell tale water mark (rusty coloured if no inhibitor, or the colour of your inhibitor) around the engine somewhere - assuming it's an external leak.
    seeyuzz
    river
    Apr 2008
    yeah its an external leak and river i have no idea what you are talking about you know way too much and i know way too little lol break it down even further please? feels like im at school again cheers guys for the info!
    Junior Member Backyard Mechanic chaRwie's Avatar
    just leave ur car runnin give it a few revs see where the water drips from
    coolant leaves a light brown colour when it evaporates, water pump is easy to change/seal on 18rs
    Sold: RA28zoku - Bosozoku inspired
    Weekend: JZX100 Mark II - VIP inspired
    New Daily: GX71 Mark II - Bosozoku inspired coming soon...
    The welch plug or core plug is the hole below.
    If it leaking it would leave stains down the side. (Had this issue with my original 18RG)
    Apr 2008
    alright sweet cheers for that guys i will check it out today you guys rock
    Melbourne, Victoria
    Have a check of the link to see what fellow Toymodders have done. I used Chemiweld on some leak that I had in my old 18rg and she kept on going strong.
    http://www.toymods.net/forums/archiv...p/t-12155.html
    ...but the link should give you some more help on the subject
    - Jackie Stewart
    Apr 2008
    okay i checked and it isnt my welch plug no leaks coming from there most likely my waterpump but everything is too close and i cant see where its coming from dammit anyway i did a compression test on the motor and it came up with 135 psi throughout all four cylinders, what should it be? i read it should be at least 170 cheers guys
    Just to confirm, there are welch plugs on both sides of the block. (like 3 on one side and 4 on the other or something)
    is the water leaking from the front of the engine?
    Can you pinpoint which part of the engine its leaking from?
    Those figures seem awfully low. Did you have the throttle opened?
    Why am i always a.. Domestic Engineer RAAAH23's Avatar
    Jul 2009
    New South Wales
    have you checked your heater tap? if you have one.
    mine was leaking and the tracking along the hose back to the water pump
    Cheers, Alex
    - 1976 TA23 2T-GTE GT3076 ID1000cc E85 Haltech PS1000, W58, G Series Diff, B45 Simmons
    Apr 2008
    i ll track the heater tap today also no it was not on full throttle i ll try again today and yes i do thnk it is awfully low cheers guys for the help rep added
    Jun 2008
    1) A water pump that is just on its way out might not leak until the engine is hot with some pressure in it.
    2) Some welsh plugs might not be visible. On my 7mge there is one behind the starter motor; another at the back of the block and the engine has to come out; and there is another up front behind the cam gear.
  1. Boost Leak Tester
    Last Post: 01-06-2006, 11:25 AM
  2. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
