while it's apart and not in there you should do that throttle body upgrade, F**K doing that when it's in the car in FF layout.. RWD was pretty easy..
you can use your existing 4AGE throttle body, as long as the wax pellat cold start works ok.. they bolt on like the 3SGE ones, but you just need to dremel or use a porting tool just to make the transition smoother, the GZE throttle body is only 47mm or so, the 4AGE and 3SGE are 55mm+ even a 7MGE bolts on.. that bad boy is a 60mm!!!
BUILT NOT BOUGHT
