Results 1 to 8 of 8
Thread: One side sagging
    Apr 2008
    Default One side sagging
    My car is on an angle at the REARS.
    Leaning to the right. I have checked suspension and all is good. So shock/springs are not the problem. Yet car is still lower on the right hand side.
    What else should I check? Control arms?
    Default Re: One side sagging
    tyres inlated?
    check all the bushings as they could be degraded in the low corner.
    How does it feel when it's rolling. Is the steering stable or all over the place under acceleration and braking?
    Are the dead hookers in the boot evenly distributed? This has been known to cause such a problem. So has sagging springs...has this happened rapidly?
    -RM.
    lostie.
    Swap rear springs side for side. Most cars have one person in them and so the driver's side tends to sag more over time.
    It can also be caused by a mismatch in height at the front. Check the front and maybe do the same swap there too.
    Regards
    Rodger
    corollamanic Backyard Mechanic
    May 2006
    left side on jack?
    Apr 2008
    tyres inlated?
    steerings a little wacked, because I lowered it and didnt do an alignment.
    Bushings is all i can think of at the moment cause i've replaced both pairs of springs and shocks in the rears and still no good.
    I even put the first pair of springs on my cousins car and they turned out to be even on his car,dam.
    Deep Fried Backyard Mechanic ONETEN's Avatar
    soooo..... what kind of car is it?
    Old School: 1971 Datsun 1200 Deluxe Coupe all original... yep factory twin cam turbo
    Daily: 2006 Hilux Dual Cab D4D 4WD
    im assuming aw11, as both male ocupants end up on the drivers seat
  1. Sealing / Adhesives for Side Skirts/Pods
    Last Post: 19-07-2007, 12:15 PM
  2. Steering help, freeplay on drivers side wheel
    By Da_Ronz in forum Tech and Conversions
    Last Post: 09-01-2007, 09:39 PM
  3. Bending downward 4cm of 1 side of a xA6x Chassis HELP ME !!!! :(
    Last Post: 03-01-2006, 05:56 PM
