w series definetly, you should really search.
want to do 3s conversion to my ke36 panno and trying to find out if either or these bad boys will fit with out too much hastle?
any help apprecited thx
wheres the R152 from?
4wd or truck varient?, could be landcruiser maybe?
Ive worked with R151's but never a 152 (in fact ive never heard of one either)
Originally Posted by WHITCHY
sorry guys i meant r154 not 152 (dont know where i got that from)
i have tryed to search maybe im just typing the wrong words not sure
Decide first your horsepower goal, then decide which box you need, then work out how to fit it.
The W58 is a fantastic box and will be a much easier fit, but will become debatably unreliable once you get up around 280-300rwhp. PLenty of people have used them with far, far more than that but personally I've changed more than a couple myself that have died at those power figures. Vehicle weight, torque output and driving style will also have an impact but anything up around 300rwhp is a nice rule of thumb for the need to consider other options.
Unless I'm a monkey, I too find the search on this site to be fairly crap.Originally Posted by rolla 36
If you have trouble with the search function, try searching the Toymods site through Google. Also the similar threads section at the bottom of the posts can often have good relevant threads in it. For example, below is a thread on W58 into TA22 which will probably be of some help regarding fitment.
Callum
you should be able to find a w series box that fits fairly easily but you will also need bell housing to suit the engine
There is also no 'off the shelf' way to bolt an R154 to a 3S (unless the 3S rwd auto uses an A340E), so that kinda makes the choice a bit simpler.
thanks guys masive help got the info i needed im gunna stick with a w58 (if i can find one) dont want masive power or at least not over 200-250 rwkw yet so look into it then
