Results 1 to 15 of 15
Thread: 1UZFE into 1999 Hilux 2x4 Spedo/Rev counter
    Aug 2012
    Gauteng
    Unhappy 1UZFE into 1999 Hilux 2x4 Spedo/Rev counter
    Hi guys
    I am putting a 1UZFE VVTI into my 1999 Hilux 2x4
    Am using original computer box and harness.
    And have been told that I cant have a Sped o or rev counter is this tru?
    Mar 2008
    Default Re: 1UZFE into 1999 Hilux 2x4 Spedo/Rev counter
    I don't know why you wouldn't be able to have a speedo or rev counter... I've used a 1UZ in a 280zx and have a speedo and tacho working fine.
    There is even a tach signal that you can get from the computer to drive a tacho. Depending on what tacho it is sometime you may need a 'booster' circuit to get a correct reading, but if you had a 4 cylinder before the 1UZ should even have the correct number of pulses due to the ignition kinda running like two 4 cylinders.
    For the speedo, does it have a cable drive in the gearbox or an electronic one?
    I know there have been quite a few 1UZ's into hilux's so I'm pretty sure with a little searching you should be able to find the answers.
    Nov 2011
    U will have a tacho or rev counter as u call it
    But u might not have a speedo
    But there is other ways around that
    First check your transmission for one or two speed sensors on extension housing
    Aug 2012
    Gauteng
    What do I look for?
    Nov 2011
    Take a pic and ill tell u
    Jan 2011
    If the sender on your box is mechanical you can also get a device to convert the signal to suit your electronic speedo or if you need a mechanical fit to your speedo you can get a pass through device that allows the cable signal to go from box to speedo + generate a signal for your ecu.
    Talk to the guys at CAE performance and tell them what you are trying to achieve.
    Aug 2012
    Gauteng
    Any paticular side?
    Nov 2011
    I recon being vvti there might be only one speed sensor
    And that's for the ecu to control the auto
    I've done late model 2j vvti stuff and they don't have speed sensor for dash
    U should have a two wire sensor for ecu
    And if there is a three wire sensor that for the dash
    Aug 2012
    Gauteng
    Nov 2011
    nope
    near hole where the tailshaft slides in should be 1 or 2 sensors
    Nov 2011
    OK lets clear a few things up.. firstly are you using the auto that comes with the UZ or going manual? If manual you won't have too much of a problem but auto then a big tin of worms is opened. Now if auto firstly you need to find out if you have a 4 or 5 speed auto. If a 4 speed then there is good news but I'll cover that after you confirm what you have. Here is why and as an example I use a UCF21 Celsior as the donor car. On these later ones that do not have the "Speedo sender" in the extension housing of the gearbox they use the left front wheel ABS sensor for the signal for not only speedo but also the Vehicle Speed Sensor for the ECU. Now I think that this signal goes to the ABS module which in turn converts the signal for both speedo and VSS so you need to find out what "pulse" this is. Being Toyota I'm pretty sure that it's 4 pulses per revolution. So in reality the speedo isn't your only problem. First thing to do here as I've said is to post up which transmission you are running and we'll go from there.
    Tacho.. being "Coil on plug ignition" there should be an output from the ECU to drive the tacho. Again not knowing what the pulse is on these engines (they aint come to WA in great numbers yet but the earlier engines triggered the tacho from a 4 cyl pulse) what you need to do is this.. Wire the tacho as normal and remove the front of the instrument cluster. on the "Guts" of the tacho you should see a "Trim pot". Now you will need a "Master Tacho" or be able to plug the engine into a scanner and use the "live Data Function", however in this instance a photo electric tacho may be the go. Run the engine at say 3000rpm and ajust the trim pot until the dash tacho reads what the master says. Job done and end of problem.
    Now while I think that I'm correct here I'm pretty sure that another learned member here will either agree or correct me if I'm wrong
    His. 2005 GRJ120 Prado VX
    Hers. 1995 KZN130 Surf (soon to be replaced by a Rav4)
    1981 LN40 Hilux Trayback ute. Now an RN40 with Surf interior
    1992 Factory Widebody 2door Surf 1UZ-FE V8 Auto, now for sale
    Aug 2012
    Gauteng
    Auto that came with the engine
    Nov 2011
    Post up a clearer pic of the tail housing of the auto and also the part number from the ECU (89661-*****) and I'll be able to identify what you have and advise you from there
    Nov 2011
    just get a gps speedo and all your probs will be gone
    who needs a rev meter when its auto anyway
    Nov 2011
    That still does not solve the Vehicle speed sensor problem
