Results 1 to 4 of 4
Thread: R engine help
    Nov 2008
    TAS
    Default R engine help
    gday i drive a 76 hilux with a 12r motor and L42 gearbox, just wondering if anyone knows if just the engine can be swapped out for say an 18r or 22r and keep the same gearbox as the motor has crapped itself?
    any help would be good!
    Default Re: R engine help
    these 12r engines have a deep skirt block, meaning that part of the bellhousing is actually a cast part of the block. 18r's and later r motors aren't like this so you'll have to swap in the 18r gearbox with it. then you need to go through every 18r engined car you can find to get the right engine brackets that make the 18r sit nicely in your hilux.
    Nov 2008
    TAS
    ok thanks for that mate have to start looking i guess! any idea of the easiest engine and box swap for these? im guessing the 18r but ya never know?
    Tasmania
    If the bellhousing is unboltable and not intergrated in with the box then all you need to do is bolt the 18R bellhousing to it and away you go.I pressume this is a 4spd column shift?
    Cheers Brett.
  1. Sams MA61 7MGTE Conversion Guide
    Last Post: 08-07-2015, 12:12 AM
  2. TG engine info!
    By MitchE in forum Tech and Conversions
    Last Post: 30-07-2010, 07:27 PM
  3. MA70 --> JZA70 Conversion
