Hey dood, you can get tps which turn the other way. http://www.efihardware.com/products/...Kits-and-Parts
The throttle body I am using is set up for the tps to read from 0 - 100% as it turns anti-clockwise from its stationery (0%) position to full throttle (100%). That is... anti-clockwise when looking at the side the TPS bolts onto.
But most TPS read from 0 - 100% when turned clockwise. . . .
Are there TPS available for anti-clockwise operation?
I only picked up on this tonight, as a mate is using the same type of throttle body and it stuffed us up as we tried using a VL RB30 TPS (clockwise one) to no avail.....
I dont really wanna rotate the throttle body around to suit a clockwise unit as that means my accelerator cable will go to the top of the circular disc instead of the bottom of it, hence meaning i have to get my accelerator cable bracket moved....
NOTE: When I refer to the direction of movement above, I am looking at the end of the D shaped shaft on the TPS mounting side of the throttle body.
Anyone got any ideas?
ah thankyou my good man! +rep for you
