Jack up back of car by the diff and put stands under the car.Originally Posted by Frankhead
1. Take off rear wheels
2. remove drum
3. undo the 4 bolts holding on drum brake assembly to diff
4. fit slidehammer to studs on axle and remove axel
5. take said axle to local work shop to get old bearings removed and new ones pressed on.
6. redo in reverse to assemble
This will probably take a few days so if you can do with your car then go for gold or else get a workshop to do the lot.
, for while im changing them would much appreciated
