Results 1 to 9 of 9
Thread: ta23 1ggte conversion
    May 2009
    victoria
    Default ta23 1ggte conversion
    hey guys just a couple of questions regarding the TA23 1GGTE conversion.
    1. do i need the RA23 cross member?
    2. does my tail shaft, being from the TA23 still bolt up to the 1GGTE gearbox?
    i have done a search and keep getting ,mixed messages to these questions.
    any information will be great.
    cheers.
    Forking Architect Grease Monkey
    Jan 2009
    S.A.
    Default Re: ta23 1ggte conversion
    ....I believe the normal Soarer TT engine mounts bolt up to an TA23 x-member...if you use a RA23 x you will need the n/a mounts with 18rc rubbers....in theory at least.
    Tailshaft is another storey, was your gearbox a W40, w50, t50 or automatic variant...if it was a w50 i cant see any problems...but im not sure about the others.
    Rotaries are cool...so why are their owners such cocks>>?
    Junior Member Backyard Mechanic {Mr Crabs}'s Avatar
    Apr 2007
    You can change the engine x member if you want,that is most simple way to mount your 1G.
    Your tail shaft is now useless you need to get one made as you have no mounts to fit the two pc RA40/28/23 one.you will also need a spline/yoke from a w series box. the T series you have is much smaller.
    I had lot of problems finding info to. members rides has all the answers but may take some time to find.
    Case
    May 2009
    victoria
    cheers.
    so the 1ggte engine mounts bolt up to the ta23 xmemeber?
    and the 1gge engine mounts bolt up to the ra23 xmemeber?
    Jan 2009
    S.A.
    ...thats my understanding....but I could be wrong
    I know that the latter is true because thats what I have atm
    The common conversion is:
    - RA23/8 xmember (often with lowered/repositioned mounts, but not necesarily)
    - 1GGE steel mounts (slightly modded to bolt to the front holes on the block)
    - 18R rubber isolators (go between the 1G mounts and the xmemeber)
    - RA23/28 gearbox xmember (modded to allow mounting 1" further back)
    - RA23/8 tailshaft (if you are using the standard diff. otherwise custom)
    - modded GA70 rear sump to clear steering links
    As far as I know, the TA23 chassis is the same as the RA23, so once you rip out the 2T and the TA xmember, your install should be the same as an RA23.
    I haven't heard anything about using the soarer mounts on the TA xmember... but with mods, anything is possible.
    Timbo
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    May 2009
    victoria
    thanks guys your help is much appreciative. My only concerne is, if i wanted to keep the TA23 xmember so i can have power steering.ill see what i can do and ill keep everyone posted on any progress
    also it will be good to have a walkthrough on a TA23 conversion for future reference
    Hmmm... how do you plan on running P/S on the TA23 xmember Mate?
    Current rides...
    2) White RA25ST
    Junior Member Grease Monkey Night Rider-TA23's Avatar
    subscribzz
  1. 1GGTE conversion into a RA28 Celica... 1ggte engine mounts?
    By MIN728 in forum Tech and Conversions
    Last Post: 21-05-2008, 10:34 AM
  2. ta23 engine conversion
    By mquinn in forum Tech and Conversions
    Last Post: 19-05-2008, 11:49 AM
  3. RA28 with 1GGTE, need some advice of the o so wise ones!
    By MIN728 in forum Engine & Driveline Conversions
    Last Post: 14-05-2008, 06:08 AM
  4. MA70 --> JZA70 Conversion
  5. Conversion decision!
    By twentyEight in forum Tech and Conversions
    Last Post: 30-10-2006, 07:35 PM
