I'm no pro but i'll try and help.
The alternator/generator will be putting out heaps of random voltages and maybe A/C as well (not sure) but you only want 13.5ishV D/C into the battery, the charging wire should come from the alternator to the external regulator thn to the positive electrode of the battery.
I don't know if your current setup is screwed though....
Are you sure your alternator charges? have you tried testing the voltage of the battery with a multimeter and then also trying when the car is running to see if the voltage jumps up while the car is running? i.e. the alternator is charging the battery....
if i did an engine transplant i would've swapped to an internally regulated alternator too....
catch, Ace
