Results 1 to 13 of 13
Thread: Spare parts for AE101 4agze
    Apr 2009
    Helvete
    Default Spare parts for AE101 4agze
    The tension roller for my supercharger belt is making noice. Where can I get a new one? The toyota dealer here in Norway wanted 250 bucks for this.
    So are there any cheaper places?
    Powered By Żywiec Backyard Mechanic Adash=P's Avatar
    South Austrlia
    Default Re: Spare parts for AE101 4agze
    Can the bearing be pressed out? If you can get a part number for the pulley, I'll source one locally and if its cheaper, I can send it out to ya.
    AE93 SX - Thrasher 20V
    JZX100 Chaser - Daily 1J lovin
    Apr 2009
    Helvete
    Sorry the bearing can not be pressed out.
    The part number is 13570-16010 , thanks alot mate.
    Chiba
    Apparently you can swap to a silvertop idler pulley, which is rebuildable.
    I'm not sure of the specifics of this conversion though, you'll have to have a search around.
    Oberst Koi-Master Backyard Mechanic
    I'm using an aftermarket 4ag timing belt tensioner pulley ($35) that I've flipped around so the bracket/spring holder is facing outwards, a different nut with more thread a washer to space it out and a washer on the nut side to center it... been working fine for 1.5 years now . will check it all over soon when I change the drive belts.
    "Welcome the dude who ain't the buyer of mugs"
    Chiba
    Can you take a photo?
    Aug 2006
    success 6164
    im using the idler pulley off a magna i think it was. i don't think there bearing presses out but they are fairly cheap.
    http://www.ae82ownersclub.com/forum.php
    powered by 4agze ae82 goodness.
    Apr 2009
    Helvete
    Some pictures! Got something new Adash=P?
    Chiba
    Is that off a stock AE101 GZE? It looks totally different to mine....
    Apr 2009
    Helvete
    Yes, I belive so. Here is a picture:
    Quote Originally Posted by defcon
    FYI that is not a stock crank pulley (looks ~175mm) or idler (stock idler would foul a crank pulley of that size).
    Apr 2009
    Helvete
    So anybody know what idler i need then? confused
    Edit: Looks like it has been modified a bit. Edge on one side is grinded down.
    South Austrlia
    Sorry for the late reply. It wasn't much cheaper so its pointless.
  1. F series Diff . P51 box and likely sources for GT parts.
    Last Post: 12-10-2006, 09:58 AM
