Results 1 to 11 of 11
Thread: 1jz without p/s
    Default 1jz without p/s
    is their any easy soplution to runnign a 1jz sep. belt without powersteering or aircon?
    only possible options i can think of is try swap the tensioner pully for a ripped one if u can get em, or ditch the tensioner pully and mount the alternator so thay u can use the alt to tension the belt (like on a 7m)
    Signiture edited..... Read the Rules
    Default Re: 1jz without p/s
    go to the wrecker's, find yourself i think it was around a vs model (v6) and grap the idler pulley off it and the belt to use without p/s and air con is 6PK0990
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    champ!.......
    12.4 @ 110mph
    infact i have that belt here you can have for $20 if you want, about 1000ks use and then i relocated the alternator and had to use a longer belt
    12.4 @ 110mph
    Slanted Photographer Automotive Encyclopaedia LeaThaL's Avatar
    Aug 2006
    thats cheap, the belt i got was 40ish ive done the same with my belt but its still got the standard round wheel, would that crush and ruin the teeth and/or throw the belt off at all you think?
    1 G L O V E
    88 Ga70 supra --- Under powered and over cooled Daily
    Quote Originally Posted by Jordan 76
    interested to know where u mounted the alternator i ideally would like mine on the pass side to match the existing wiring loom as this 1jz motor is just a temp thing till i finish off my 7m
    Quote Originally Posted by LeaThaL
    it will wear the belt out alot quicker, plenty o commonwhore's at wreckers, the ribbed pulley is a direct bolt on
    I just copied TOY77's idea off his thread, it almost bolted onto the other side of the block using factory bolt holes, though i did have to shave a bit off the actual alternator to get it to sit flush with the rest of the pulley's.
    12.4 @ 110mph
    thanks jordan. i will go this path also. but cheers for the help and offer on the belt.
    did u decide to keep the factory tensioner or just make up a similar tensioner to toy77s aswell?
    factory tensioner
    12.4 @ 110mph
    so your bell style idler pulleys (ones without grooves/teeth) are only designed to take the backside of a ribbed belt and runs the risk of flattening the teeth of a ribbed belt if run the other way?
    JZA70|R / 12.45 @ 111 mph.
  1. 2jz Bottom End 1jz Head
    By P.I.M.P.I.N. Soarer in forum Engine & Driveline Conversions
    Last Post: 17-04-2013, 06:27 PM
  2. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 08:13 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 05:25 AM
