If you are pulling the engine apart and want it to last, MHG and forgies would be my recommendation. You will need the head and block to be machined ultra smooth and flat, so make sure you take it to a shop that has experience with this sort of thing (or these engines preferably). ARP head studs are worth their weight in gold for a properly sealed 7M, as they wont stretch anywhere near what the factory jobs will. Studs also won't twist as much when you torque them up as bolts do. Forgies are nice to have but the standard jobs should cope with 18psi. Of course, if youre going to the expense of a proper engine rebuild and, once again, want it to last, I'd certainly consider them (in fact I did). What turbo are you planning to run BTW? A CT26 is never going to see 20psi
