Results 1 to 15 of 19
Thread: If you could build your perfect 1jzgte what would the build involve ? And what car ?
    Junior Member Backyard Mechanic MOOKIE's Avatar
    tas
    Thumbs up If you could build your perfect 1jzgte what would the build involve ? And what car ?
    I know its kind of a " piece of string " question but for arguments sake just say; somebody else is paying for it and you can put it into what ever car you like.
    Go ahead have a dream !
    Mookie
    Jul 2007
    Default Re: If you could build your perfect 1jzgte what would the build involve ? And what car ?
    whatever car I like?
    alfa 105 series GTV. you can have fun getting it to fit
    66 Galaxie XL Coupe, with a 427 SOHC.... I guess the 1J would suffice as a starter motor
    1JZ-GTE - Forged pistons, (bigger bore, standard stroke) 8.5 to 1 comp ratio, Forged + balanced rods, balanced crank, port polished head, 1.2mm head gasket, 287 / 264 deg cams with 10mm lift, 3071 turbo with larger inlet turbine, 4" dump to 3" exhaust all the way..20psi low boost, 30 psi high boost boost, hope to make 400 to 500hp thereabouts at rear wheel.. i could list brands but that would be advertising
    and i'd put it in a BMW E46 coupe.. with a 1.5 way lsd under it, twin plate clutch, 5 kg flywheel.. yadda yadda..
    Just wack one into an AW11 with like 1000hp
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    Quote Originally Posted by Spectre
    Already tried fitting one into a SW20, it's wasn't gonna happen.
    1994 GZX90 Mark II 1GZ-FE V12
    about 800 hp and hits full bost at 3000 rpm, in a hot looking car that can fit 335s for traction......
    this thread is pointless
    Signiture edited..... Read the Rules
    Convictania
    I agree,
    but still - I'd like one in an ra28.
    *shakes fist at jeffro*
    (thats how I say hello)
    The perfect 1JZ is a 2JZ.
    This is not a tech thread
    My KE25 thread
    Brisbane
    Slammed white MX23, manual single turbo/VVTi job.
    jetpilot Automotive Encyclopaedia 1JZ.747's Avatar
    8.3 et PB 169 MPH PB
    Quote Originally Posted by Shifty
    That is horn. Requesting more photos!
    Resident Mitsu-whore Backyard Mechanic
    Oct 2008
    2JZ bottom end, forged internals, VVTi 1JZ head, custom plenum, custom tuned length turbo manifold, Haltech E11v2, maybe a T04Z, or a T66, running about 30psi yadda yadda looking at about 750-800hp.
    Car? Either a dumped metallic bronze MX32 on 15x7in Watanabes or SSR Longchamps, or a Z20 like this one minus the wing, and a set of 17x8 and 17x9in gunmetal Volk GT-Cs
    30 psi thorugh a 66mm turbo aint going to produce 750 800hp
    I Hate Being A Carport Converter Clown's Avatar
    That is all sorts of win!!
    GZE AW11, M40b18 e30, 1J cressida
