most cams or aftermarket cams have 2 set ups lobe center and lift at tdc lifter rise ,
on the tdc lifter rise you need to bring no 1 cyl about 80% before tdc set up magnetic base and dial indicator and set this up so it is on no 4 cyl .on the inlet preset the dial indiactor so its 300 thou into the bucket and clearing the cam .now turn the dial so it sits on 0 .now start moving the crank and keep watching the dial until its starts moving { as lobe starts to go down the bucket } keep a eye on the tdc mark and count how much the dial indicator moves from 0 until you are at tdc if it has moved 150 thou thats what you have at tdc
if the card says 165thou at tdc then you would need adjustable cam pulleys to get it in its place
once you have set them up and thats both and use a black texta to mark pulleys and belt
gently slide the belt of at tdc and then try to move the inlet cam towards the exhaust and keep track how much movement there is till it stops if you have 80 thou after or more you are ok but if you only have say 20 thou you will have to fly cut the pistons
this set up needs the spark plugs out as well so it will turn easy as well
on the exhaust to set up take it to tdc on no 1 then do the same with the dial indicator preset it agian at 100 thou and see when you turn the crank down to the bottom to bdc see how much its moves till it stops moving and that will be how much it is at tdc for the exhaust
