You need to look at the Trans/Axle code on that little silver plate on the firewall on the halfcut. I think Witzl has posted the different codes, maybe JP as well.
Superstrut is easy to spot as it has the twin piston callipers.
What is your recipient car? If you're putting it in an AE92 then choosing a MAP AE92 4agze is the easiest option.
My silvertop got 85 fwkw after an emanage tune. They go nice with a TD04L on them and about 6psi
Open up the oil filler cap and check for gunge. It should be nice and clean in there. In Japan a car will get a sticker on the cambelt cover when the belt is changed. But the dates are in Japanese format (the year of the emperor, of something.)
C52 is the older 5 speed box on the 4ages
C56 is better. - 04C I think is the factory LSD. - 15C is Open Centre.
Is it C150 that is the 6 speed that came as an option with the Black Top?
Also 85kW is a TRUCKLOAD more than 65kW in a light car like an AW11.
