Results 1 to 4 of 4
Thread: w50/ae86 gearbox crossmember
    Default w50/ae86 gearbox crossmember
    just wanna know what gearbox crossmembers ppl are running in their ae86 with the w50 celica gearbox... need some help. just not sure if its easiest to make one from scratch, or customise an existing one. cheers for any help
    Junior Member Grease Monkey craigy's Avatar
    Default Re: w50/ae86 gearbox crossmember
    I'm sure there a heap of people who have done this mod, but i think the easiest way to do it would be just to fit the gearbox and dummy fit the t50 crossmember and see if you can use it.
    If not i'm sure making one from scratch wouldnt be too difficult, even if you dont have a welder, get yourself a 4inch grinder and some steel, cut and drill everything to suit and take it to someone to weld up.
    good luck
    Craigy
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    New Zealand
    Here are pics of the W58 crossmember in my KE70 Ute. May give you some ideas for the W50 crossmember.
    This was made by a mate when he owned my ute, with a different engine you may want to sit the engine/gearbox back a little. The 18RG needed a bit more firewall clearance.
    Callum
    thanks mate this points me in the right direction..
  1. Verifying a w58 gearbox
    Last Post: 09-10-2008, 10:39 PM
  2. AE86 Gearbox Conversion Options
    By Garth AE86 in forum Tech and Conversions
    Last Post: 20-03-2006, 01:30 AM
