Results 1 to 8 of 8
Thread: 34ADM Carby on a 18R Engine
    May 2009
    Default 34ADM Carby on a 18R Engine
    Hey guys,
    I've been havin a bit of trouble with my 18R endind up being the carby so i went and got a falcon carby off an XE(was recommended by a few people) and i bolted it up and everything now i just gotta get it running. anyone done this?
    I need to know where all the vacume hoses and stuff go(or if i can just remove them) and also what size jets are the best for them.
    also a pic of how the throttle cable goes would be handy
    thanks in advance guys.
    Default Re: 34ADM Carby on a 18R Engine
    I have done exactly this... quite a few years ago though.
    I tuned it by soldering & redrilling the jets (many, many times). It took a long time to get it running well.
    A couple of photos that might be helpful (this is when it was on a 21R though)
    #1
    #2
    Red vac line block off.
    Green vac line went to vac adv on the dizzy.
    The throttle pulley i made up from 3 pieces of 3mm alu plate.
    The wire for fuel shutoff and electric choke goes to ignition power.
    May 2009
    cheers, thats the info i was after, do you have any pics of the soldering & redrilling of the jets ? can't you buy replacment jets for them?
    thanks again
    Nope, no photos of the jets.
    Clean em up, carefully solder just the jet tip (not the full length), then use small drills (under 1mm) to make the size hole you need.
    Some tips:
    Tune the primary jet first. While doing so, have the secondary jet fully soldered closed, so you can work out what the primary is doing first.
    Primary jet size will probably be larger than the one it comes with due to the lower vac from the smaller engine.
    May 2009
    sweet, will give it a go
    will it still run with the stardard jets?
    Yup, it will
    Tasmania
    Yes you can buy the jets not dear at all.18R's usually run well with 1.35mm in the primary and 1.40mm or 1.45mm in the secondary.If the jets haven't been changed in the Falcan carb it will have 1.35mm primary and 2.20mm secondary.
    Hope this helps.
    Cheers Brett.
    May 2009
    sweet cheers, so basically just change the secondary jet and should be ok?
    also do i have to change the idle jets or anything else.
    cheers guys all your help is very appreciated
  1. Toyota R Engine History
    Last Post: 02-12-2011, 09:41 PM
  2. MA70 --> JZA70 Conversion
  3. Cooling Systems - Overheating Problems.
    Last Post: 24-06-2006, 09:40 PM
