sound slike what you need is one of those relays that only closes when it is getting spark signal from the coil..
volvos use them and other cars also use them...
if you just use coil power or whatever, still doesn't mean engine is turning over..
if you use an oil pressure sender switch, then it might stay open afterwards (although another relay would help there.... so maybe you could use one of them)
but spark triggered relay is prolly best bet... if engine stops... so does the gas...]
