Can't help too much with the K&N unfortunately....... but ....
I'm running Unifilter socks on my 4AGE [150mm long 53mm I.D. 83mm O.D.] and it only picked up 1.5 hp by taking them off.
I'm changing that setup to a fabricated flat panel foam filter arrangement and sized the filter panel at 1.7 metres per second face velocity (like air conditioning filters) which suggested a piece 250 x 250 was ok for 1600cc at 8000rpm. (I'll actually be using about 400x400 to be sure)
That size [250x250] was also suggested by Unifilter - so for foam filters at least something around 1.7 metres per second face velocity would be fine.
If you can work out the area of the convoluted panels on the K&N and (I'm guessing) use a slightly lower face velocity (Say 1.5m/s) that should give you a ball park guess.
