Results 1 to 11 of 11
Thread: 7afe oil squirter block??
    got 71? Grease Monkey cooter's Avatar
    wa
    Default 7afe oil squirter block??
    hey all
    been searching around about 7agte's and found a post on the old forums that got me wondering.
    "already bought argo rods with aries pistons on a late oil squiter 7a block with 16v head with a gt25 turbine "
    is there a series of the 7afe that came with oil squirters as standard?? if so what sorta year corollas do these come in?
    pretty keen cause the extra oil cooling could be beneficial.
    craig
    Te71 Corolla Levin, Blacktop 20v
    Te71 Corolla Levin ex Rally Car 2tg.
    Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
    Ke70 Corolla 4dr Sedan
    Ae86 Corolla sprinter 4ac
    Corolla Feind
    Default Re: 7afe oil squirter block??
    Wouldn't surprise me if it's the lean-burn TVIS 7AFE, we never got it in Aus.
    Jul 2008
    Auckland
    Now 9AGTE 410kw atw
    GameOn Backyard Mechanic Poggy's Avatar
    Yes funnily enough i have seen a 7a block with oil squirts, dont ask me where it was from
    wa
    so basically its look for a hard to find standard block or machine the 20V ones in.
    hmm
    is there much work involved with machining holes in a non squirter block. ive already got a 4a block with them for placement. like just drill and tap holes into the oil galleries in the right spots?
    bazda
    ive seen your setup (very nice) and youve relieved the crank for them. is this something i can do or job for a machine shop?
    craig
    Corolla Feind
    Jul 2008
    Auckland
    Now 9AGTE 410kw atw
    wa
    thanks bazda. much help and very appreciated.
    craig
    Corolla Feind
    Mar 2010
    So how hard is it to put oil squirters in? and how do you go about it?
    Relatively easily, you just need the right tools (or the right machinist with the right tools).
    The oil galleries on a 7A line up in exactly the same place as 4A's, so you just have to mill four flat sections (so the squirters can sit flat and not leak everywhere), drill and tap into the oil gallery on each bore, and then drill locating holes (IF you want to, but not necessary). You literally replicate the exact same deal as GZE/SP/20V's.
    Mar 2010
    So just take the measurements off a 4a and transfer across to 7a, do the cranks foul at all?
    On the 7A i worked on (Oly 86 on ae86dc), the crank came within a few (3-4mm) of the bolt heads, but that's still more than enough that we weren't concerned.
    Another thing you will have to check is that your piston skirts don't touch the squirters. Some aftermarket (and GZE) pistons have notches for the squirters, and some pistons have a more 'aggressive' slope on their skirts that they clear, but it pays to check.
  1. pressure tested and problems
    By 2revup in forum Tech and Conversions
    Last Post: 18-02-2008, 04:11 AM
  2. 2TG head/ 18R block
    By quikestsilva in forum Tech and Conversions
    Last Post: 08-06-2007, 02:36 PM
  3. 2TG head onto 3TC block...need help
    Last Post: 15-05-2007, 09:07 PM
  4. 4AGE 16V block vs 20V block.
    By WHITCHY in forum Tech and Conversions
    Last Post: 21-02-2007, 10:05 PM
