1. nope.. i have a returnless system in my car and i've swapped a walbro GSS342 (255 lph) fuel pump... most toyota returnless system i know of have the fuel pump as part of the filter assembly.. so changing the fuel filter involves removing fuel pump as well. i know of people swapping over different fuel pumps, from S15 silvia to mitsubishi FTOs etc etc and it works fine..
2. fuel pressure regulator is at the bottom of the fuel filter assembly..
3. the returnless system is designed such that fuel is not returned to the system,.. it has merit, but can be endlessly debated i.e. hot fuel coming back, fuel getting lost as vapour, more parts needed for return system, etc etc... turning it to a return system involves a different fuel rail (which has a return line) a tank that has a return line, fitting return lines to it, fitting a fuel pressure regulator, etc etc... it can be done, but in my opinion the returnless system is efficient and i wouldn't bother messing with it...
4. there are no requirements... i've seen people fit the 2AZ engine (which has a returnless setup) to a car that has a return ... they had to modify the car a bit to fit the 2AZ's fuel tank, as it was much easier to use the fuel tank for that engine, for the correct fuel pressure regulator, fuel filter and fuel pump..
5. voltage wise, it's the same as a conventional fuel pump as far as i'm aware, but i might be wrong.. that said i've seen people run a relay to power the factory pump, as well as a relay to run a walbro.. i just ran the walbro off the factory wiring, had higher pressure at the engine, was easier than messing around with the fuel pressure regulator..
6. unfortunately my fuel pressure would be different than yours.. as i have a smaller engine.. i can't remember what the pressure was at idle and under full throttle but the fuel pressure gauge i had read 2.8 at idle and 4.0 on full throttle.. if it makes sense?
7. with the factory fuel pump it only runs hot when i drive it to 1 liter left in the tank.. like most other normal in-tank fuel pumps? with the walbro if it gets to anything less than 5 liters left in the tank it will whine like a bitch..
hope that helps, otherwise i have some general technical info regarding returnless systems for some toyota cars, and it identifies the components of the returnless fuel system.. it's the same for all FWDs but i think it's very similar for RWD cars as well..
