1" = about 2.5-3 deg negative camber..
that is a long way to tuck in.
unless you run a better offset, you will HAVE to run flares, or get the guards flared out an inch.
to work out what springs to buy, find an old TEIN catalogue.. the current one only goes to AE100. fronts are likely to be AE92 but rear is a bit different to 86.
as you say, he is after the tough look, so dont worry about what makes the suspension work
either get the front guards rolled out a long way, or flared in metal, or accept that the tyres won't be under the guards.
with that much scrub radius, it will probably be a bit shit to drive
here shows the different spring sets for older toyotas
http://www.zoom-bane.jp/shop/h-toyota_ra.html
AE95 = TO105006SDF
AE92(SC) = TO105005SDF
AE92 = TO105004SDF
AE86 = TO105002SDF
but no info on the actual springs..
have you talked to ANY spring or suspension shops yet?
AE10x have different TRD springs for both front and rear, even tho spring rate is same
http://trdparts.jp/english/parts_spring.html
not many places list AE95 as it is too old.
