Results 1 to 14 of 14
Thread: Removing axle bearings, T-series...HELP
    Backyard Corolla Kid Grease Monkey
    Default Removing axle bearings, T-series...HELP
    i smashed an axle in my T-Series, i have a spare axle sitting here, however it has a smashed bearing...
    so what i need to know is, how can i change the bearing from my snapped axle onto my other axle without killing the bearing?
    any help appreciated
    Default Re: Removing axle bearings, T-series...HELP
    get them pressed off and on by a shop
    but bearings are hell cheap. good excuse to get new ones
    perth
    the t series bearing in oz is about $100, and most times there a bastard .
    heat and a press gets them off. (heat will kill the bearing but i normaly replace them anyway)
    with the lock ring, i usualy chisel them off.
    it wont be expensive to get a shop to do it.
    100?
    i was thinking mor elike $30 each..
    perth
    yeh its crazy, probably becuase its a pretty big bearing.
    i think the cheapest ive paid for them is around $85 each, the S series are around $30 for the kit haha
    I could swear I paid about $65 for a pair not so long ago! CBC is where I got my kits from
    Now - RA23-WRX
    yeah 100$ just doesnt sound right to me, $65 for a pair is more like it
    try get another price
    perth
    well that sucks haha, a few years ago i paid $80 odd each.
    New Zealand
    go to an engineering bearing shop with one of the old bearings
    please, no more PMs!
    Yeah absolute waste of time trying to swap the bearings. The bearing collar will need to be cut with a 1mm cutting disc on an angle grinder. Without going all the way through, and being very carefull not to cut into the axle. You then use a cold chisel to snap the collar open. Use a hydraulic press to press off the old bearing and collar. Press new bearing on, heat collar with oxy and then drop it onto the shaft.
    So if you do not have the tools and equipmentm get a shop to do it. Any differential repair shop will do it for you. They will also be able to supply the bearing and collar, along with the new axle seal you will need. The whole lot comes as a kit. You would be a mug not to replace the seal while the axle is out for bearing replacement.
    cheers Chuck.
    MS51Crown Coupe,
    don't use a oxy for heating, a oven or bar radiator will give sufficant heat.
    Quote Originally Posted by Silly75gt
    Bit hard when you only want to heat the inner race of the bearing.
    I agree that cutting them off carefully is the easiest way to get them off.
    I have used a sandwich press/sandwich maker with success.
    The heat is only required on the retaining collar, not necessary on the bearing.
    cheers Chuck.
    MS51Crown Coupe,
    Victoria, Mt Macedon
    Maybe the huge disc T series bearings are $100 a pop, but I've paid 30-40 for the standard Aus bearings several times.
    And it's a job I can't be arsed doing. So the guy down the street gets a six pack and bearings get changed.
    Hen
    By The Witzl in forum FAQ
  2. EOI - Cruise to Drift Aus Series @ Easter Creek
    By driftedmz20 in forum Previous NSW Events
    Last Post: 23-06-2008, 01:32 PM
  3. Replies: 23
    Last Post: 14-02-2008, 04:53 PM
  4. Guide: How to build a K series motor
    By oldcorollas in forum Tech and Conversions
    Last Post: 19-10-2007, 09:43 PM
