Results 1 to 5 of 5
Thread: e51 gearbox help
    Feb 2008
    New South Wales
    Default e51 gearbox help
    im swapping the gearbox in my aw11 and when i was taking the drive shafts out of the replacement (the wrecker had just left the tulips in) this metal flexi ring came out as in the photo. what is it? i couldnt seem to find it in the BGB
    Sep 2008
    Default Re: e51 gearbox help
    it could be synchronizer ring and hub sleeve for the transmission.. as according tohttp://www.club4ag.com/faq_and_tech_pages/aw11_mr2_tuning_guide.htm <<<that site, they can fail so check that
    also im not 100% thats what it is... but that is my guess
    The GOD HAND AW11 - sold
    kyle that is really crappy internet psuedo knowledge... it isnt even close to a syncro and not even in the right department
    sleepy: is hazzard a guess given the blurry photo that it may well be the wire support ring from the inside of the drive shaft seal.
    pop the seal out and id take a bet that the seal is missing the ring which will casue it to leak like a bitch when you put it in.. get the seal, eaisly avaliable from toyota for ab out $15 from memory. worth changing both of them as its buckets easier when its on the ground and you havent got the drop the oil out again etc etc
    Sep 2008
    yeh i just remembered reading the site and seeing the pic... was just a thought as i stated....
    no harm done...
    北海度
    toof is correct...
    it is a circular spring that sits around the inside lip of the drive shaft seal... which means the seal where that shaft came out of is no good till you pull it out and put the spring back in its place... can't be done while the seal is in the box.
  1. W58 into TA22 Celica
    By sillycar chick in forum Engine & Driveline Conversions
    Last Post: 09-09-2014, 01:18 AM
  2. Verifying a w58 gearbox
    Last Post: 09-10-2008, 10:39 PM
  3. How-to: Converting an MR2 gearbox to FWD (SW20 to ST162)
    By buck naked in forum Tech and Conversions
    Last Post: 27-12-2006, 06:22 PM
