Results 1 to 12 of 12
Thread: diff slop
    Junior Member Domestic Engineer urantia's Avatar
    Default diff slop
    My G series LSD has got too much slop for my liking, clunking everytime i change gear unless i'm VERY VERY gentle on the clutch.
    Can the preload/nut on the diff flang be adjusted to take up some of this slop/excessive play? or when a diff gets like this does it have to be rebuilt/overhauled or best off to replace with a low km unit?
    98 3rz-fe Hilux 4x4
    Default Re: diff slop
    That preload nut may well not be the problem mate. It could be any part of the setup.. I'd be pulling the center out and seeing where the problem exactly is.
    Facebook | LinkedIn
    So there isn't really a common reason for this excess play? such as "yeah such and such is worn/out of adjustment".
    Could be any number of reasons?
    Reading on supraforums.com a ton of ppl complain about this diff slop, no doubt from constant abuse and accelerated wear.
    Ah i hate taking my diff out > but looks like i will have to pull it apart and locate where the play is occuring. (really hate trying to lift up a g-series diff into place, fuggin heavy)
    Still if anyone has something to add i'm all ears.
    98 3rz-fe Hilux 4x4
    User Conversion King
    NWA
    i think what you have is backlash. the way most live axle toyota diffs work, (being a front loader diff) is that there are 2 large rings that can move the centre in an axial direction.
    these large rings are a little smaller than a donut and have threads on the outer edge which screw in/out to move the diff centre axially, ie. from LHaxle side to RHaxle side.
    with this adjustment, the crown wheel can mesh with the pinion gear better .
    so yeh, i think you need to loosen the bearing caps and then adjust the "adjusting nut" accordingly
    hello
    NWA
    hello
    Thats what i was thinking! backlash adjustments! Vague memory of how to set it properly from a toyota manual i no longer have.
    Thanx for the link!
    Pos rep for you.
    98 3rz-fe Hilux 4x4
    I would be looking into the backlash possibility, but be aware that when lsd hats are too far gone will make a very nasty clunk, particularly when changing gears. Had that problem with my boyfriends skyline after too many burnouts.... still held together tho well good luck, let us know when you find the problem, I am very interested in learning more about diffs.
    Toyota Car Club (Qld)
    NWA
    hello
    Thanks! Thats a really cool resource... I knew the basics of how it worked etc, interested in learning about analysing problems etc. They are a pretty basic concept. The pictures are cool tho!!
    will do sillycar (keep you updated with LSD findings).
    98 3rz-fe Hilux 4x4
    Tallahassee, FL USofA
    side gear & pinion/spider gear play controlled by thrust washer.
    NOT the drive pinion.
    Please do not F with backlash.
    right you are then. Going to try this out on my spare diff first (which also has worse slop then my current diff)
    Cheers all.
    98 3rz-fe Hilux 4x4
  1. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  2. changing the gear ratio's in hilux diff.
  3. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 08:13 PM
  4. GA70 diff compatibility with RT142
    Last Post: 20-03-2006, 09:05 PM
