Results 1 to 11 of 11
Thread: rwd 3sge. What dizzy???
    Mar 2008
    Default rwd 3sge. What dizzy???
    A mate and i are putting a ser.1 3s in his ae71 and were just going to mount the engine forward so the dizzy will clear the fire wall.
    But i was curious as to what others have done to change the dizzy so the engine can be mounted further back?
    Iv heard that you can use the internals of some sort of mitsubishi dizzy mated to the 3s one to run external coils with a ignition ecu. But what type of mitsubishi dizzy?
    May 2006
    Selangor
    Default Re: rwd 3sge. What dizzy???
    here's what I did http://forums.cjb.net/cccm-about560.html ,thats a modded dizzy with 4g63 (VR4/EVOs?) internals. Whatever ecu you'll be using make sure it supports the coded trigger wheel in the mitsu dizzy or else you'll be building junk. Happy modding
    Mar 2008
    cheers mate ill look into this a little closer.
    any other ideas guys?
    queensland
    i have done several of these and used the toyota dissy
    Quote Originally Posted by terryo
    What does that mean?
    You use a toyo dissy and relocated it? or you kept the original position but mounted the whole engine forward? Some people dont like engines hanging out there front grill.
    queensland
    i relocated it to the front. made special adapter to drive off the front of the cam, shortened the dissy drive shaft and made a alloy bracket to mount it all and have normal dissy adjustment. I have a workshop and do this sort of stuff all-day., everyday
    Junior Member Domestic Engineer 1jz68u's Avatar
    mine had it mounted in the normal spot
    see here
    and here is the part number
    Glenn
    Current Ride http://www.toymods.net/forums/showthread.php?t=41123
    Previous 3SGTE ST162, 1JZ Cressida 215RWKW-ET 13.318, Celsior, XT forester, 3SGE KE70.
    Quote Originally Posted by NME308 View Post
    You do of course realize forgiveness is easier to gain than permission right???
    Cheers, Jason
    Mar 2008
    terryo- how much do you charge for the kit to relocate the dizzy?
    1jz86u- What is that dizzy from?
    pretty sure when i looked it up it was a gen 1 3sge one. but will check again
    Glenn
    Cheers, Jason
    not exact number but close for a gen1 3SGE from a celica
    http://www.toyodiy.com/parts/p_J_198....html?hl=19100
    Glenn
    Cheers, Jason
    Mar 2008
    Quote Originally Posted by 1jz68u
    OK i think the one on the series 1 that we have is different
  1. [Guide] 2T, 3T-c & 18R-c Electronic Dizzy's. "How To"
    By GA61XX in forum Tech and Conversions
    Last Post: 24-06-2015, 09:25 AM
  2. 4AGE 100kW Dizzy Oil Leak Guide
    Last Post: 05-11-2014, 09:00 PM
  3. TUTORIAL: How to build a 'cheap' 5S-GE motor from 5S-FE
    By bajachris88 in forum Tech and Conversions
    Last Post: 21-07-2010, 10:15 PM
  4. 3SGE differences?
    Last Post: 04-04-2007, 06:46 AM
