Results 16 to 30 of 67
Thread: GT3076R 4agte help guys
    S.A
    Default Re: GT3076R 4agte help guys
    "Should" being the word. Its easier said than done over 250 rwkw.
    I ran a .83 the boost response was fairly linear. It was more of a smooth gradual pull in the car than the usual full hit as it comes on boost.
    I have switched the .63 from the .82 also. It hasnt been driven since though so i have no idea how much better the response is. My last dyno was with the .82 so once it goes back on the rollers ill check it at the same boost level to see if there is any gains there.
    I also want to know what cr you'll be running, and what pistons / rods if you don't mind letting us all know
    S.A
    Pistons and rods are decent pauter rods.
    Im unsure on the rest of the bits
    Check his rides thread.
    South QLD
    Thumbs up Re: GT3076R 4agte help guys
    Found this MR2 in NZ with a 3071 (3076 core) making 306kw .48 a/r
    http://www.youtube.com/watch?v=5ofaxw6UWxs
    its a large turbo that i recon would work on a Ge eng ,,
    Feb 2007
    Timaru
    I think dx20vt has a similar setup but then change to a 7a bottom end to reduce the amount of lag.
    linden
    I never ran that on the 1600 motor, had various versions of T28's on that, but they were on there limit at that.
    I run the GT3076R with the .63 housing and it's laggy enough,
    after 5000 till we get full boost, starts around 4000, makes about 8psi at 4500,
    and that's on the 1800cc motor.
    Makes a good 440hp atw on 20 psi, and the turbo just seems to be coming into it's 'good' range about there,
    so I dunno how'd it o a a 1600, especially with the big housing on the rear.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Junior Member
    Jul 2008
    Christchurch
    30/76 with a .63 housing ftw, mines got a .48 and it struggles to make 306kw as the little ex housing is making it choke. Kinda depends how hard you wanna rev it and how seroius you go with the head. more than 300kw is possible and not that hard with a bigger turbo and good fuel but starts to get pretty laggy.
    Current ride: Sweeeeeeet Hiace, 3L power!!
    Project: AW11 4agte, 410kw 555hp on 26psi, 11.1 @125mph, more to come
    Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
    Quote Originally Posted by 4agtepwr
    Is that 306kw at the flywheel though?
    I'd imagine you'd have to be pushing closer to 30psi to pass 300rwkw from 1.6L - guess it depends on the rpm aswell.
    Junior Member
    Jul 2008
    Christchurch
    At the wheels and 23 psi, Its all about being able to make and hold peak torque at high rpm with a little motor. We rev mine to 9000 at the drags and makes peak torque at around 8300. The heads about as modified as you can go with a 4age with out going to oversize buckets and the cams are over 300 deg duration and over 10 mm lift. The trade of with very big cams is it makes an engine dull off boost as it bleeds of comp with all the overlap. Then a big turbo makes it worse again.
    at flywheel it should be around 340-360kw at 23psi, if it is maintaining VE at 8300
    the 306 might be a little lower on aussie dyno (?) but it is still up there
    Junior Member
    Jul 2008
    Christchurch
    Well 123mph trap speed says to me that its def making the power and it will go faster on that tune with a few more issues sorted. Why would it read lower. Its was tuned on a fairly new dynopac hub dyno with correct corrections and no dodgy air temp alterations or TCF factors. Dynos and workshops can bulshit but mph doesnt. With a 3582 and c16 it would make 500whp no worries, the only problem with that is my lack of $$$ and motivation to do that.
    nah, dyno-dynamics dynos in oz (with the shootout mode etc) tend to read a bit lower than US or hub dynos... due to the way they ramp up, etc....
    my point was just that with a good build, the flywheel should be well above 306kw
    S.A
    I am told dyno dynamics read lower too......... but what do you do? A dyno is only really to compare your own engine against its self and tune to see if you can make gains in hp or torque. from one run to another.
    Unless two different engines are run back to back on the same day it hard to pit one against the other.
    But we all still do
    To make that sort of power at that boost really does make me think im missing something somewhere though.
    Hmmmmmmm LOL
    as a rough guide
    kw = (engine size x 100 x (1+ boost) x rpm) / 9402
    where engine size is in litres, boost is in Bar or atm)
    4A should be between 150Nm to 160Nm depending on how much you have improved or retained efficiency... harder at high boost
    Jun 2007
    You really need to pull ever trick in the Book to get a result you'ld be happy with.
    I remember a former street king turned full time drag race setup saying he envied his old street setup and wished he never changed it. Big numbers are just that, big numbers.
    It doesn't mean it will be faster around a circuit then your old setup. I think if you just aim on getting more power almost everywhere, then you will be satisfied with the result. 300Kw's in a FWD will spin the wheels in any gear at any speed you want and the resulting Engine reliability and cost of such a setup is not sensible by any stretch of imagination.
    If I were you, I would get the reverse designed Mitsubishi Evo Twin-Entry Turbine Turbo which is available with a Titanium turbine wheel (500rpm quicker spool), and upgrade the intake side to a 20G Compressor cover and comp wheel. Easy 240Kw atw and unrivalled response considering the standard TD05H Turbine wheel weighs considerably less than the GT30 turbine wheel.
    Add to that the shortest and smallest internal volume exhaust manifold you can make and then see if you still need bigger cams.
    Gearwhore. Backyard Mechanic
    Oct 2008
    I figure if you're not just a dyno queen and have the dollars, go twincharged. More response, less peak hp but definitely a more driveable torque curve.
    The above opinion is just that - my opinion. It is not shared by any business that I am currently or have previously been involved with, nor any of their employee's.
  1. 4AGTE - Exhaust manifold warping
    By tan18d in forum Tech and Conversions
    Last Post: 05-05-2009, 06:36 PM
  2. 4agte clutch setups
    Last Post: 26-06-2008, 12:32 PM
  3. nitrous & 4agte
    By caibs in forum Tech and Conversions
    Last Post: 16-08-2007, 11:46 AM
  4. Getting 4agte conversion done... where in perth shall I go?
    By AE101LEV in forum Tech and Conversions
    Last Post: 25-05-2006, 08:59 PM
