use the 20V waterpump with the metal gasket that has the flap that directs water into the block correctly.
Use the blacktop timing belt, gates have a listing for the belt now or even an off the shelf gates belt for a BMW works.
I'd use the 16V or an AE101 20V oil pump housing personally so you don't have to use the AE111 hydraulic timing belt tensioner ram.
Any reason why you're going with the 4agze pistons and not a proper set of forged 20V pistons which will give you the correct squish areas for the head?
			 4AGTE Blacktop engine build up
