Results 1 to 10 of 10
Thread: what metals can be welded together
    Default what metals can be welded together
    i was wondering what metals can be successfully welded together
    i.e., stainless to alloy, mild steel to...uh...titanium
    what can be welded
    The boobs are back
    Default Re: what metals can be welded together
    i know that its very very hard to weld hi-tensile bolts to mild steel.
    i am more-so thinking about welding exhaust piping to alloy, or any type of 4-5 inch tubing
    The boobs are back
    Forum Member Grease Monkey scootaphill's Avatar
    victoria
    carbon steel to stainless ect is ok but cannot be welded to alloy steels...
    make sense
    phill
    ON HOLD Current Project 1UZ-FE Powered Buggy
    Last Project 18R-GEU time to tinker
    EDITED ITS ALL VERY LAMO
    You can't weld different metals together. Aluminium alloys to ferrous alloys = no go.
    2 words for you guys
    browns gas
    google and you might be suprised what you can weld together
    nah, brown gas, pfft.
    2 more words
    Hot Glue
    You would be suprised what you can join together.
    Too much preperation on the hot glue. If it can't be held together by any combination of cable ties and gafa tape then the gods have spoken! The 2 items shall forever remain apart!!
    Tim.
    2 more words
    Hot Glue
    i'm not tyring to put sequins onto my car
    The boobs are back
    - this browns gas?
    Professor Yul Brown has developed a machine that will convert plain tap water to a stoichiometric mixture of hydrogen and oxygen without causing an explosion, hitherto fore thought to be impossible to do. He has discovered another state of water besides ice, water or steam. It is Brown's Gas! One liter of water makes 1860 liters of Brown's gas, when a spark is added to the gas, it still does not explode, it implodes. Brown's Gas implodes! When it implodes it makes the most unique welder in the world. People who can weld, confirm that it is impossible to weld dissimilar metals, glass to metal, metal to brick, and just about anything to anything, but you can with Brown's Gas Welder.
    The same pumpkin colored flame can weld aluminum at 900 degrees F, can braise copper at 1800 F, or put a hole through fire brick at 3600 F. This same pumpkin colored flame can sublimate tungsten at over 13,000 degrees F. and become the same temperature of the sun at 8,000 degrees Celsius! This machine will revolutionize the field of welding.
    thats a scam by the way...
    you can braze ferrus and non-ferrus materials together, but thats not fusion welding.. bottom line, you can't easily weld one metal type to another metal type... (eg steel to aluminium) it hard enough to weld metals of the same type but different compositions (eg sand cast aluminium to pure aluminium etc)
