Results 16 to 30 of 40
Thread: TranAxle for 1UZ?
    Default Re: TranAxle for 1UZ?
    Quote Originally Posted by Sigmeister
    Rest assured, your not the only person who's wondered how this would go.
    Question I have is, is there any harm in putting the engine in the front, transaxle in the rear?, clutch and bellhousing at the front still, tailshaft running from engine through to gearbox. Questions there I guess is how tough does your tailshaft need to be? obviously would need to be VERY well balanced too @8000rpm+... Aside from the obvious $$$ factor, what other engineering issues would there be?
    '77 RA28LT #2 ← 2.2L 18RG...
    Domestic Godess, NOT Domestic Engineer clubagreenie's Avatar
    Porsche 928 has front engine/rear trans axle.
    Look for a transaxle with the gearset behind the axleline. They do exist, 80's F1 is an example, the input shaft runs over the diff and the gearset drives forward to the diff.
    Friends
    perth
    one of my dads mates got a complete gearbox made out of a chunk of ally about 8 or more years ago. It cost him 20k and you have to turn the car off to select reverse but it happily supports 650+hp at the wheels.
    its a twin turbo gt40, i think it may be my dream car it even has aircon hahah.
    but yeh be prepared to pay because most ns transaxles are weak or expensive.
    Quote Originally Posted by RAd28
    No different to a standard tailshaft in 5th at 6000rpm
    Alfa V6 also have gearbox (and clutch?) at the rear. A 'torque tube' takes rotational power from motor down to box. Am not sure if they use any uni joints of sleeves in the tube?
    The alfa box is quite a largish/longish lump of alloy.
    Yeah, alot of the newer big $$$ cars, like the Aston Martins, Fezza 599, Corvette etc have the front/mid engine, with rear gearbox... but I guess the question is more about retrofitting something like that to an older car...
    Peewee - that's a good point, I guess worst case would be flooring the gas pedal in top gear (or overdrive?) that way the tailshaft sees maximum torque and revs....
    Junior Member Too Much Toyota GUN METAL's Avatar
    mid mount RA = SWEEEEEEET !
    Thought about that along with NS mounting a 1UZ in the trusty AW = $$$$$$$$$$$$$$$$
    ever see the Giocattalo was an old alpha sprint with a holden 308 mid mounted, bloody works of art, something like a 20k transaxle in those puppies and that was 15-20 years ago.
    I love the idea but its going to need some SERIOUS engineering, assuming you want it to drive like a mid engined exotic.
    MY BELOVED AW11...Updated members ride thread>>>>http://www.toymods.net//forums/showt...=4584#post4584
    AW11s always welcome in my driveway !
    Forum Sponsor Conversion King
    Dec 2006
    The tourque tube is pretty much just that, a large tube used to connect the engine to the gearbox, it has a bellhousing on the engine end and runs a driveshaft/tailshaft through the guts to the transmission. they are also used to maintain proper alignment of the engine and transmission and as a result are fed "torque" through them by the 2 trying to spin opposite directions.
    'Linden
    Junior Member Backyard Mechanic slipway's Avatar
    brisbane
    just randomly i saw a g50 adaptor plate sell on ebay for $101 a few weeks ago.
    GA
    Found one company who makes adapters when looking at putting my spare 1UZ in an SW20 MR2. http://www.kennedyeng.com/vw_por.htm
    edit: Just noticed the link posted much earlier.. whoops.
    I'd be very interested in seeing a 1UZ MR2 setup. Still have the engine and car sitting around, just too much money needed for a strong Porsche transaxle.
    Bill Strong put a east-west V8 into his MR2
    http://www.v8mr2.com/
    site hasn't been updated in a while so not sure if it was finalised.
    Also check the http://forums.twobrutal.com/ forums as some members there do some crazy conversions.
    Stumbled across this on the 'tube
    http://www.youtube.com/watch?v=Tg3exnYKkR
    No other info unfortunately
    Ive seen a few Ultima GTRs with 1UZs. Believe they use a Porsche transaxle
    924's ran a torque tube also
    edit: and a whole car is worth nothing
    Sep 2009
    Northland
    I reckon the later model subaru sti, 6speed would be the way to go, can handle gd power ,and you can pick them up for around 3500$ in NZ,
