Page 13 of 34 FirstFirst ... 3111213141523 ... LastLast
Results 181 to 195 of 496
  1. #181
    Jun 2008
    For sure,
    When I have it going.
    That would be awesome
    -A
  2. #182
    I'll send an email to the editor, Leo Simpson, to have a look at your thread here and see if he is interested.
    Karl.
    ...... butt scratcher?!
  3. #183
    Jun 2008
    Cheers Mate,
    I finally have my welding gear sorted out, so should see some more progress this weekend.
    -A
  4. #184
    Jun 2008
    Default No pistons, no fuel, no worries! Toyota Sera EV Conversion 'more battery box stuff'
    Update
    Thursday, 13 August 2009
    Finally got my welding gas sorted out last weekend & weather was good enough to get the first coat of paint on the completed battery box.
    Ooh so silver
    Since the weather has been bad this week I though I should finish off the battery vents & block up the great big ‘tranny tunnel’ hole.
    Cutting out more holes
    The vents were made out of some light gauge galvanised steel off cuts, these were then glued & riveted to the chassis. The same stuff was used to make up a cover for the tunnel hole.
    More different holes
    Once the weather dries up somewhat I will give everything a coat of zinc ‘cold galv’ paint & install the battery box.
    -A
  5. #185
    Chiba
    Gonna put some mesh over the vents? Might help stop any nasties getting in.
  6. #186
    Jun 2008
    Yer, will see what's laying round the shed
    Will also put some foam around the base of the box to fully seal up the airflow when in position.
    -A
  7. #187
    Lite-n-Stouty Grease Monkey Nitephyre's Avatar
    Props, this is mad shit... can't wait to see how it turns out
  8. #188
    Jun 2008
    Talking Batteries, Batteries, BATTERIES!!!
    Update
    5:47:58 PM
    Monday, 24 August 2009
    Woot Batteries are finally installed!!!
    Cleaned up vents
    High voltage connectors for ZILLA, Battery Charger & ACC’s
    Final test fit of box
    All batteries installed!
    Now for the fun job of wiring up all the links & BMS modules!
    -A
  9. #189
    Chiba
    Needs moar battery....
  10. #190
    T'ville, QLD
    lnk all de ba2rez 2ge4
    me was trying to save time
    2T out 4A in....
  11. #191
    Junior Member Backyard Mechanic manny's Avatar
    Thumbs up Re: No pistons, no fuel, no worries! Toyota Sera EV Conversion begins…
    First of all, top effort here - I've been subscribed and folllowing this thread for a while and I'm amazed with what you have achieved.
    Now these last pics have me a little concerned about any occupants forward of that battery box in the event of any frontal collision. I presume you've got it covered but I thought I'd mention it anyway.
    Do the math on the force that will be exerted by the total weight of that battery load at any given speed and then work out up to what speed those brackets will hold before letting go and crushing anything in front.
    Also try and work out what force will be applied to the top centre of the largest panel in the battery box as all the batteries try and make their way out of it in an impact if the floor mounted brackets do hold.
    Just looking at it, I'd be inclined to add some substantial horizontal bracing to the box across the front of it as well as adding some additional braces from the top of the box to the bodywork to prevent it twisting/tipping.
    Keep up the great work and regular updates
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
  12. #192
    Jun 2008
    -Manny,
    Already taken care of!
    There are front & rear right angle brackets which go along the top edge of the box & bolt into the chassis.
    All up there are about 30x 8mm bolts holding the box very secure
    The car will most likely desentergrate around the box!
    -A
  13. #193
    User Conversion King
    NWA
    looks fantastic mate.
    i tried doing some calcs the other day, it becomes pretty clear how the usable distance depends onthe velocity you want to do.
    its a cubic relationship; double your speed and youll use 8 times more power!
    since the aerodyamic drag dominates the overall drag, its also clear that the lowest possible Cd is best
    will you look at adding wind trays to the bottom of the car?
    what sort of distance are you looking to travel with it and at what speed?
    also, what charging time would you estimate on single phase GPO?
    hello
  14. #194
    Jun 2008
    -brett_celicacoupe
    Yes speed vs required power is a biggy, then throw in an incline and watch the power usage go nuts!
    I have done some rough calculations & rekon I should be good for about 150 - 200km level ground @ 60-70Km/h.
    Its just too hard to work out all the variables.
    Bacically I will be happy if I can get to work & back in one charge. (about 75K with long incline on the way home).
    Will 'suck it n see'
    Expect to see loads of power logs & results once the controller is hooked up, Ill try to gather / post as much info as possible when it runs!
    -A
  15. #195
    Jun 2008
    ^Charge time approx 8 hours on a 15A GPO (%80 DOD)
    Last Post: 08-01-2006, 12:27 AM
