Results 1 to 4 of 4
Thread: 5 speed into corona RT104
    Apr 2008
    Default 5 speed into corona RT104
    Howdi all i was wondering what sort of 5 speed celica gearbox i need to put onto the back of my 18R in my RT104 rona
    Nov 2007
    Default Re: 5 speed into corona RT104
    Easiest I expect would be the W50 as most if not all would have been behind R series motors to start with and so should bolt straight up to the engine. The only other thing you may need to change is the g/box cross member. This may just be either a swap between using and auto or manual cross member or just turning it around 180 degrees to line up the holes. Should be a easy fit I'd think as I imagine the RT104 would of had a W40 manual in it which is basically the same g/box but without the extra bulge for the fifth gear in the rear extension housing.
    Other thing to check is the number of splines on your current g/box output / tailshaft.
    If you are sourcing from a celica W50 were in all 2lt celicas up to and including RA40s
    RA28 (18RG)Members Ride
    RA40 (3TGTE)
    RA40 (18RC)
    SXA11R Rav4 Cruiser
    ACA33R Rav4 Cruiser
    Dead on GT1978.
    I put a W50 in my RT104 (replacing the W40) years ago... was a simple bolt up job.
    The shifter did come out at different location though, i did need to extend the hole in the tunnel for it.
    You can get the right shifter location just can't remember what car it came from. Performed the operation about 15yrs ago.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
  1. st141 corona 5 speed gearbox?
    By xlr8_07 in forum Tech and Conversions
    Last Post: 04-06-2008, 12:55 PM
  2. Corona RT104 homologation papers needed
    By Tamsey in forum Tech and Conversions
    Last Post: 21-04-2008, 11:31 PM
  3. Toyota's Abbreviations
    By Radar in forum Tech and Conversions
    Last Post: 16-02-2008, 03:19 PM
  4. KE 35 conversion from 2 to 3 speed (auto)
    By woody012 in forum Tech and Conversions
    Last Post: 02-01-2006, 11:12 PM
