Results 1 to 5 of 5
Thread: 1g-gte A340e with 1jz?
    Nov 2007
    Default 1g-gte A340e with 1jz?
    Can an A340e from the 1g-gte be used behind a 1jz-gte as I got a spare one lying around, will it mate up, will wiring be an issue and the speed sensors?
    If it's possible, what bits Do I need to make it fit.
    Thanks.
    Default Re: 1g-gte A340e with 1jz?
    it will fit as the bellhousings are the same, just depends what year/ car ur 1jz is out of to see if the loom will work etc...speedo sensors are interchangeable
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    i tried this . . . didnt work , different splines
    RA23 1JZ VVTi 373hp - SOLD
    12.4 @ 110mph
    THE EVOROLLA 262.9hp - SOLD
    Nov 2007
    The 1jz-gte is from a 1992 Toyota Soarer.
    The A340e that I want to put in the 1992 Soarer is coming out of a 1989 GZ20 from a 1g-gte.
    Jordan which splines are different, input or output?
    sorry, the convertor spline's are different. I suppose you could make it work if you got a stally made up? but is it worth it?
    12.4 @ 110mph
  1. Turbo Exhaust Housing 1JZ Question.
    By Soarer_D00D in forum Tech and Conversions
    Last Post: 20-06-2007, 07:13 PM
  2. JZX81 1JZ: Analogue Dash Wiring
    By mamba in forum Engine & Driveline Conversions
    Last Post: 19-05-2007, 04:04 PM
  3. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
