i wouldnt use mls gasket with the steel o-rings, copper is best for orings if you use a composite gasket you will still have the metal fire rings around the cylinders and they tend to blow, well when i had o-rings and i tried composite gaskets they never held together so i ended up machining the o-rings off.
toyota will stock the pump sorry i dont have part number (ask for the pump from the car the motor came from, there generally ok at finding what you want)
you can get arp studs and cometic or copper gasket from coventrys (they wil get it from rocket industries)
for that 10mm timing bolt and o-ring, toyota might have that in stock as well.
autobahn will have eboost2 and stuff, look on turbosmarts web page for dealer location.
