Results 16 to 21 of 21
Thread: Need advice/opinions on hilux brake upgrade
    Forking Architect Grease Monkey
    Jan 2009
    S.A.
    Default Re: Need advice/opinions on hilux brake upgrade
    ...is there a thread on here concerning how to change an entire braking setup?? from pedal to distribution block?
    Forum Sponsor Conversion King
    Dec 2006
    what do you mean be entire brake setup?
    from pedal to distribution block? sounds like a pedal box arrangement but i could be mistaken.
    entire brake setup i would consider to be pedal box + front and rear calipers and rotors but then again thats just my opinion.
    linden
    Jan 2009
    S.A.
    ...yeah, itsnot really that simple lol...each model is different with pedal boxes and such...i suppos i was thinking with keeping an original pedal cluster (in my case an ra23) and updating the booster and MC, but keeping he pedal box
    ...seemed relevant since it would also help jap1 here make an informed decision...
    May 2006
    tas
    dont forget you can grab a wilwood bias adjuster, they are cheap as chips.
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    yeah i was planning to use a wilwood bias valve. did some measurements of the pedal yesterday and came up with 1.52:1 as the pedal levarage ratio, in another thread roadrunner said when running no booster you should make the leverage ratio 1.6:1, reckon i'll be right if i do that? i really don't think i'll get a booster behind the brake master, when the clutch master is so close and the wiring loom exits really close to it on the other side.
    Dec 2006
    Read some of the articles in this before you go planning to mod things too much, http://www.stoptech.com/tech_info/faqs.shtml
    They also have some good info in the Technical white pages also, be sure to have a good grip on the situation before you make decisions that could put both your life and other's lives at risk (not saying that you will, just hoping you won't)
    Linden
    By The Witzl in forum FAQ
  2. Celica Brake Upgrade
    By fuzz! in forum Tech and Conversions
    Last Post: 21-05-2014, 01:33 PM
  3. information on 1GGTE into RA23, hilux,crown,carona pug brake upgrade, hilux diff.
    By celica77 in forum Engine & Driveline Conversions
    Last Post: 15-05-2007, 12:14 PM
