Results 1 to 5 of 5
Thread: Pilot Operated Check Valve
    Default Pilot Operated Check Valve
    I'm looking for a small, brake fluid compatable, pilot operated check valve/shuttle valve.
    Does anybody know of a factory type or can think of a valve that could be modified to achieve the same result?
    Tallahassee, FL USofA
    Default Re: Pilot Operated Check Valve
    A drag racers front wheel line lock?
    That has been thought of, but i'm trying to achieve a hydraulic parking brake that is independant of the main brakes and doesn't rely on any external power supply. I know it takes bugger all power, but I still want it to be battery free. I may still end uo using a electric shut off valve. A solenoid operated directional control valve (DCV) may also do the job.
    Jun 2006
    If it is used in an automotive application, I dont think it will be considered roadworthy.
    If you are planning to alter brakes in an aeronautical application (Pilot Operated).., I dont think CASA would be impressed either
    Jun 2008
    Hydraulic handbrakes are not permitted unless you have both a hydraulic & mechanical handbrake. Some rally cars have both to be registerable.
    Burkett sell all types of electric solenoid valves. Ask if they have a brake fluid compatible seal.
  1. HKS valve spring ( max lift )
    Last Post: 07-11-2011, 06:20 PM
  2. Included valve angle on a head
    By trd3sg in forum Tech and Conversions
    Last Post: 23-01-2007, 08:41 PM
  3. Blocking ABV with aftermarket ecu
    Last Post: 17-01-2007, 12:09 PM
  4. how to check and test drive a car before buying.
    By pwrn in forum Tech and Conversions
    Last Post: 02-10-2006, 09:26 AM
