Results 1 to 5 of 5
Thread: F LSD diff noise pinion or bearing? rebuilding
    Default F LSD diff noise pinion or bearing? rebuilding
    hey guys,
    Diff in my ma61 has been noisy for a while and im looking into replacements/rebuilding.
    The noise: Loud whirring noise would say higher pitched, loudest at 100kmh above 120 almost silent and its pretty quite below 80 ish. Only when its accelerating. As in if i sit on 100 and i accelerate its noisy back off noise is gone. From the research ive done it seems to be the pinion/crownwheel is worn. Its a bit clunky too but that part doesnt bother me just the dam noise.
    What im wondering is, is that bearing or pinion noise?
    If its pinion/crownwheel noise and i rebuild the diff with a trutrack center then the noise will still be there correct?
    Thanks for you time, bit of noob when it comes to diffs
    nath
    Default Re: F LSD diff noise pinion or bearing? rebuilding
    Could try runnin some Nulon or similar Additive in there and see if that quietens it any ?
    11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series Soarer And 1st into the 11's WOOOT!!!
    Still going good
    http://www.youtube.com/watch?v=tc_7aRUGshw
    its hella noisey no addative is going to help ive accepted this diff is toast (still locks up lsd most times though)
    Quote Originally Posted by naten
    If you re-use your existing CP, yep! Bearings should all be changed when going to a new centre, so if it's bearings that should be no issue
    thought as much dam you greg you should of sold me your diff
  1. DIY: My Celica-Supra (MA46/47) differential swap into AE86 & info.
    By assassin10000 in forum Tech and Conversions
    Last Post: 15-12-2008, 02:12 PM
  2. T series rear end diff centre change guide (warning, pics!)
    Last Post: 30-05-2007, 11:57 PM
  3. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 12:41 PM
  4. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 08:13 PM
