Re-calibrate your tps just for piece of mind.
But it could be all different things
Hey guys ive got an 86 twincam and recentley its started stalling and idleing low when the temp get slightly over half. Drives fine but when you pull up at the lights it runs rough and then somtimes it stalls starts straight away after it dose though. Anyone else had this happen to there car? or have any ideas what might be causing it? Thanks in advance
car could be overheating dude
have you checked your coolants topped up?
i had the same issue and it was a BHG
The GOD HAND AW11 - sold
Adjusting the idle is easy on 4AGE's.
Theres a screw near the throttle body that you can loosen a bit to raise the idle.
AE93 SX - Thrasher 20V
JZX100 Chaser - Daily 1J lovin
mine did the exact same thing when it was really hot (melb heatwave) but went when the heat went. Can you make it idle properly by using the accelerator? if this is the case just adjust up the idle. It could be a host of things such as a partially blocked injector, leads etc.
