Results 1 to 15 of 23
Thread: Hub Clunking/Creaking on Start/Stop/Direction Changes - Not tight enough?
    cease striving Conversion King RobST162's Avatar
    Default Hub Clunking/Creaking on Start/Stop/Direction Changes - Not tight enough?
    Hey guys,
    I hope some of you may have experienced this before and can throw me a little help.
    Have finally re-assembled the Group-A and it's driving well enough. However it seems when I start or reverse from stop there's this funny 'creak' from the hub area.
    I can't totally isolate it, but have checked suspension/ball joints etc and it's all nice and solid when I jack it up.
    I did the driveshaft nuts up with a nice tube on my breaker and well above factory torque I'm sure.
    I also notice that in mid-corner the wheels seem to 'shift' a little and the 'reset' once it's straightened out.
    Is that a problem any of you are familiar with?
    There is NO bearing noise when travelling and the car has bearings maybe only 18 months old with limited k's. Before I changed the clutch things were fine and in regards to the driveshafts I had them inspected, re-greased and re-booted professionally before re-installing.
    Love any thoughts.
    Rob
    Default Re: Hub Clunking/Creaking on Start/Stop/Direction Changes - Not tight enough?
    "mid-corner the wheels seem to 'shift' a little and the 'reset' once it's straightened out" = suggests suspension bushes squirming under load or steering looseness somewhere?
    Nov 2007
    Maybe frozen brake calipers for the creaking noise when taking off from a stop.
    lower ball joints and lower control arm bushes. had constant trouble on both my 162s, even with urethane they still seemed to 'shift' and move about
    Have you double checked the CV nut? I had one come loose a while back when I neglected to use the torque wrench on it and just did it up FT with a big breaker bar - worth checking for the time it takes
    The big 19mm nut on the ball joint would be worth checking too, I've seen them work their way loose before and cause a sloppy feeling when cornering
    East west cross member done up tight? Check all the bolts that hold the LCA to the chassis as well
    Bolt check anything that you had undone just to be certain... or better, bolt check everything!
    I am the sun
    Is that feeling in the ass end ? I had that feeling real bad because my rear shocks were shagged and I think the rear trailing arm bushes are known to move round heaps on our cars. Once I fitted coilovers i didn't have too many issues, it still does it a bit but no where near as bad.
    Quote Originally Posted by RobST162
    Careful with that.
    I believe that is what caused my sheared nut on my drive shaft.
    Also with it tight it is putting more load into the bearings.
    27.90s @ Esses Hillclimb
    nah it's in the front end
    I can't pick it.. just a big 'click/creak' on change of direction and slow speed I noticed it most... or more frequently when starting at traffic lights
    front end for sure.. ball joints are good.. steering rack.. good.. suspension nuts.. good
    pillow ball mounts?????
    I didn't know it was possible to make a driveshaft "too" tight.. I mean.. it's not as tight as some of the ones I've taken off.. but I could go nuts on it and make it tighter if I had to
    Well i wouldn't have either, but the sheared CV joint changed my mind.
    I can't prove it failed because it was too tight, but i know it was done up to buggery when i had it apart before hand, and you can clearly see the twist that was left after it broke.
    Interesting.. I'm having this same problem in the arse of my supra at the moment. To me it sounds like the suspension possibly not seated properly... which I plan to check when I get it up on the hoist next week
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    Quote Originally Posted by Roundy
    Careful with that.
    Yeah, the result of an overtightened nut looks like this.
    It also felt "a bit" wonky and the car had an odd rattle rolling into the shop.
    The rattle was explained when the wheel was pulled off and this fell out of the center cap:
    I don't think the guy could have gone another 100 meters without the wheel falling off or some serious brake damage. The wheel bearings had worked themselves quite a long way loose. It cost him a new wheel bearing and driveshaft. IIRC they had to replace the hub carrier as well, but not sure about that one.
    Moral: Use a torque wrench.
    When unable to find one, calculate the right torque from your weight (standing, not bouncing) on a certain length breaker bar, assuming the bar is close to horizontal (if it's not, just use distance from the socket in horizontal direction only). For torques this high, that actually works quite well. (e.g. 200 Nm -> 20kg on the end of a 1m long bar, 300 Nm -> 60kg placed 50cm from the socket)
    And it will seem a lot less tight than when loosening said nut, but you know how it goes... loosening a bolt always takes more torque than tightening it, especially if it's been untouched for 10 years after tightening. As always, torque specs assume "spin nut by fingers" clean threads.
    '73 TA12 Carina - pushrod power project
    '77 TA14 Carina - 1GGTE swap in the works
    '77 TA23 Celica - 1UZ swap abandoned, selling shell to someone with JZ plans...
    the brake caliper holds it all together....
    Cost me the driveshaft, bearing, hub carrier as well.
    wa
    do you have pillow ball top mounts on your front struts? if so they will cuase a knock/clunk sound,
    shouldnt cuase any funny movement at the front tho.
    yeah I do.. is it possible to lubricate them do you think?
  1. 3SGTE tight cam belt
    By strat in forum Tech and Conversions
    Last Post: 17-02-2009, 06:00 PM
  2. arp main/head studs finger tight or tension
    By legend in forum Tech and Conversions
    Last Post: 24-03-2008, 08:19 PM
  3. How critical is a tight sealing vacuum hose?
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 29-05-2006, 01:24 PM
  4. Gearbox TIGHT as!
    By Koffee-Black in forum Tech and Conversions
    Last Post: 13-04-2006, 04:45 PM
