Setup/Installation Part A
Disclaimer - It has worked for me so far as of 08/06 I can't guarantee it will work 100% for you nor can I comment on its effectiveness YET. I highly recommend sitting down with a friend who's actually very well versus with EMB/EMU otherwise you will NEVER get a satisfactory result. Yes, if a Tuner reckons he can wire up and tune an EM cause its like any other ECU, be very aware. EMs are temperament and one wrong thing during installation or tuning and its a nightmare.
Okay this was installed on an AE111 Blacktop 20V running a Blacktop ECU Manual.
Trust Parts:
E-Manage Ultimate Part# - 15500501
E-Manage Ultimate Suppliment 1.5m Harness Part# - 15901501
NB: There is a 2.5m Harness Part# - 15901502 if you need longer
E-Manage Blue AE111 Specific Harness Part# - 15910902
I was going to try and wire this up myself but confused myself badly so I got my very damn good friend to do this while I played the assistant.
Jumper Setting - Keep it as Trust Factory Setting so it should be:
JP1 - Open
JP2 - Open
JP3 - Open
JP4 - Open
JP5 - Open
JP6 - Open
JP7 - 1-2
JP8 - 1-2
JP9 - Open
JP10 - 1-2
JP11 - Open
JP12 - Open
JP13 - Open
JP14 - Open
JP15 - 1-2
JP16 - Open
JP17 - 1-2
JP18 - Open
JP19 - 1-2
JP20 - 1-2
Wiring - Forget about it being Plug n Play even with the Specific harness, the Supplement harness or Connector C I believe from memory... It has to be wired into the Spec harness, hope you have a lot of practice at wire stripping and cutting kids.
NB: Pin Out diagram is looking from the BACK of the plug not the front. Stupid I know but its very easy to confuse yourself thanks to the Japlish translation.
Reaching the Stock ECU - Fun times ahead for those that worked on AE111s... The way we approached it was to removed the bottom half of the dash (Yes you can thank Toyota's ingenius interior designers for the moduler system) and then remove the stock ECU from that stupid below center console mounting position. This will all your wiring to be preserved nicely, allow you room to work with, relocate the bitch and for me most importantly not get bunched up/bent/creased. Relocate the stock ECU and EMU somewhere nice =)
