oh so many questions....
well, firstly, id like to state that there is a whole WEBSITE / forum dedicated to 1jz / 2jz into cressidas. i believe its called toyotacressida.net..........
anyway... to start with your questions...
1
from my research so far i have found that for a 2jzge conversion i need jzx81 engine mounts, 2j or 1j auto bellhousing and the motor should bolt in. its a 1989 model will it still bolt in?? or does it have to be a 1990 or later?
yes jzx81 mounts will be fine, or else you can use jzx90 mounts, but they have to be swapped around. as far as the year model goes, i believe the 8th month?1989(dont quote me on this one, cause im not 100% sure)(PLENTY of writeups on it) was when they changed the crossmember angle around to the correct one. yes bellhousing will bolt up.
2
also about wiring? heard mention that you can use a 7m loom on a 2j but what about the fact that 2j is MAP or could you just use the 7m AFM on the 2j?? and run the 7m ecu?
i dont know a lot about the 2jzge ECU but i do know that it has been done before so its probably just a matter of getting a main plug from a 2jz - ge'd powered body. if you have the complete engine loom then you'll see which plug you need! and as for the MAP sensor, it shall be fine considering your not using the 7m ECU your using the 2jz one
(correct me if im wrong, but only the 2jz-gte is MAP sensor, is it not????)
3
also what accessories can be swapped over from the 7m?
accessories? what for? lol but seriously, the things youll have to think about are : power steering lines radiator hoses... umm thats it i think... ill edit once i think of more.
4
do i use the PS & A/C pumps from 2jz (will 1jz work?) or 7m and will lines match up still?
yes use the pumps. NO the power steer wont match up, - you'll have to work something out there.
all in all, the BEST and MOST logical choice (however hard it may be to find) will be to just get a auto jzx81 half cut, because EVERYTHING bolts up, (unless you can afford a manual, in which case go nuts with that!)
so i hope this has helped you somewhere, my 1jzgte cressida is a great car to drive everyday, certainly makes these kids in v8 commonwhores wonder what happened just then when they tried to drag me at the lights and they just got eaten by someone with a bowls hat on the parcel shelf.
cheers,
grant.
EDIT: just read that quote, yes, do that. i was just tryin to earn a bit o repp by sounding like i knew what i was on about
