Page 3 of 3 FirstFirst 123
Results 31 to 45 of 45
Thread: 2jzge or 1jzgte into mx83
    Default Re: 2jzge or 1jzgte into mx83
    That all depends on the vagrancies of the A340 you use. Ive heard of some people having no issues, and others having lots. YMMV.
    May 2006
    tas
    my head is aching a little..
    the speed sensor (where a cable speedo would plug in?)
    -JZX83 in the build
    -UCF11 Daily....... Ha
    <3 7M sludge pump
    There are 3 speed sensors on the A341. One is the speedo drive gear for the dash, the others are SP1 and SP2, which are used for shifting and ABS i think too. Commonly the SP2 gets disabled as not all the slipyoke shafts have the hall effect wheel on the shaft to drive it.
    http://www.toymods.net/forums/showth...z+speed+sensor
    That thread sheds more details. Of course all of this can be resolved by converting it to a real gearbox.
    Quote Originally Posted by ae71
    2jzge is a good option, it was also what i was going for originally. ive been in a mates jza80 (which are heavier) and that thing pulls very well and will do the biggest number on the speedo with ease. the 1jz is a much revvier option. i went the 2j for the extra toque (about 80 NM) it also makes peak toque and power at lower RPM so you dont have to rev the date out of it to make it move.
    Where are you getting your figures from?
    2JZ-GE
    165.49 kw / 6000 rpm
    284.39 Nm / 4800 rpm
    1JZ-GTE
    205.94 kw / 6200 rpm
    362.85 N*m / 4800 rpm
    The 1JZ shits over the 2JZ for both power *and* torque. Neither are particularly great engines for towing as they both have torque peaks quite high in the rev range, something the VVTi versions fixed.
    May 2006
    tas
    sorry... yes i did make a muddle of that post..
    1jzgte has aprox 80nm more toque then 2jzgte according to wikipedia.
    2jzgte (non vti)
    206 kW at 5600 rpm
    435 Nm (doesnt say at what RPM)
    -JZX83 in the build
    <3 7M sludge pump
    Triptek Enhanced Backyard Mechanic triptek's Avatar
    If your planning on a 2jzge conversion, find yourself a jzx91 halfcut. That model 2jz uses a slipyoke, and the wiring is laid out very similar to a mx83.
    Turbora28 - I saw your post in my for sale thread. My engine package will be up for sale again in about one month. I just did the timing belt and waterpump aswell.
    1994 GZX90 Mark II 1GZ-FE V12
    I think you made a muddle of that post too... keep trying.
    Fwiw, as i said above, 2JZGE 138rwkw, 1JZGTE 148rwkw. Same dyno, same day, 15-20mins apart.
  8. #38
    Mobile Backyard Mechanic PeteH's Avatar
    May 2007
    Geez if that's right I'm glad I went VVTi GTE......186rwkw stock.
    Pete
  9. #39
    May 2006
    tas
    so what about this gearbox trickery..?
    ive brought a jzs147 2jz-gte
    ive already got a jzx81 auto
    am i going to be able to use the auto with it. (i think the kouki aristo may of had a 5speed auto, but this is a zenki so im fairly sure it uses the 4speed.)
    -JZX83 in the build
    <3 7M sludge pump
  10. #40
    Yes you can use the aristo auto. You'll either have to swap the 7m output shaft onto it or get a custom tailshaft made to suit the 3 prong rubber donut.
  11. #41
    May 2006
    tas
    i dont have an aristo auto box, i have a 1jz jzx81 auto, the same as the old 7m one basically i think. just with the JZ bellhousing.
    -JZX83 in the build
    <3 7M sludge pump
  12. #42
    Then it doesnt have a donut.
  13. #43
    Forum Sponsor Conversion King
    Dec 2006
    Whats wrong with the 1J? all the conversions ive done have been dynoed with 165+rwkw.
    For the price difference in the 1/2cuts and the fact that the only extra stuff that really needs to be done with a turbo conversion being an intercooler+piping and fuel pump (you can mate it up with the factory exhaust for the time being) i would definately swing with a 1jzgte.
    From personal experience the 2jzgte is a wiring nightmare and changing to slipyoke boxes can make it even moreso, hence why i would recommend a 1jzgte as its the easiest that will provide decent power, economy and be reliable.
    If its auto, towing will be a breaze as the converter will allow the engine to provide the right amount of torque you need at the time, but a large oil cooler for the trans will be required for towing car trailers etc.
    Linden
  14. #44
    Well i'm picking up a 1jzgte jzx90 frontcut on Monday..
    1996 FZJ80 Landcruiser.
    Email : [email protected]
  15. #45
    May 2006
    tas
    Linden
    it does seem the 2jz will be a bit more difficult to wire up.. but ill probaly be paying someone to do that.
    i ment will 2jz ecu run the jzx81 auto?? i know the tail shaft will be fine.
    -JZX83 in the build
    <3 7M sludge pump
  1. gt35r 1jzgte to gt35r 2jzGE............. Flame away lol
    By 1jzDan in forum Tech and Conversions
    Last Post: 15-03-2008, 06:45 PM
  2. 2JZGE into MX83
    By rvrolla in forum Tech and Conversions
    Last Post: 21-05-2007, 09:16 AM
