How much for the other wade cam?
Ah... crap... no dizzy gear on it, or is there?
Got dyno pics?
I'd say you might be right on the overlap - you were probably getting a fair bit of blow-through. Fresh mixture exiting the exhaust. Was it noticably rich on acceleration?
You might benefit from re-fitting the wade cams and retarding the inlet 5 or so degrees to reduce overlap and increase the advantage of pressure after BDC. The stock cam might do the same.
I dont suppose you know for sure how to tell what degrees the stock cams are? I picked up a bluetop, and I'm assuming from the 28mm base circle and 35.56mm overall height that they're 240* 7.56mm cams. Is there a part number though?
Bah! I realised what SOTP means![]()
(10 is max)) Next over 3 or 4 drives I remmapped Volumetric Efficientcy, which was MASSIVELY improved everywhere, especially low RPM, and had to back my timing off 6 degrees at full boost to stop detonation.
, mine are not that extreme, the 267s (grind 872A) are 220 degrees at/above 50 thou of lift. I guess the hassle of machining the dizzy drive might as well be avoided if possible to sav-a-da-money.
