Results 1 to 7 of 7
Thread: XT130 engine conversion
    Apr 2008
    Default XT130 engine conversion
    Howdi all i have a 1981 xt130 corona sedan and at the moment it has a 1.9L Holden Starfire engine in it(hunk of junk). Can anyone recommend another engine to drop in it even though i think it might be a big job with engine mounts etc but anything has got to be better than this holden junk.
    Corolla Collecter Backyard Mechanic Trent-KE30's Avatar
    Default Re: XT130 engine conversion
    i heard you get the rt132 crossmember bolt that in (from the XX model), and you can run your p00 18rcs and the like lol, i can vouch for the p00 starfire i had a wagon, paid nothing for it, did 1 good burnout in it and stripped 5 or 6 teeth off the cam gear, biggest pos eva made.
    Trent
    1977 Toyota Corolla KE30 1GGTE http://www.toymods.net/forums/showth...post7372821977
    1987 Ford Falcon XF S Pac
    Tasmania
    Don't need to change crossmember at all.18R-RG bolts straight in with mid bath sump.3T also but not sure on whats needed.
    Cheers Brett.
    I don't want to be a Domestic Engineer bnicho's Avatar
    Holden red six bolts in if you move the radiator forward.
    Brett Nicholson (bnicho) - Greendale, Victoria
    I own Corollas, Crowns, Prados and
    Various leaking British things...
    Quote Originally Posted by bnicho
    Yes i've heard of some people doing this for the lols. It's fun when you can't turn corners.
    Currently in the early stages of an 18R-G conversion for my Xt130. It's not too hard, still nutting out a few fine points.
    Hmm well there you go, some old bloke I was chatting to said, you get the Crossmember out the XX model (18R), how common are 18rc mid sumps? never knew there were a thing.
    Tasmania
    All 18R powered Celicas,Hiace, 2 and 4WD Hilux,RT 132 Corona run mid sumps.All XT 130 including XX from 79-81 are the same crossmember but from 82-83 XX ran 21RC so Crossmember may be different but not sure.All early XX had Starfires in them.
    Cheers Brett.
  1. Toyota BEANs, Multiplex etc
    Last Post: 14-12-2016, 07:21 AM
  2. 4agze ae92 AFM - Complete guide - doin it the hard way
    By ONETEN in forum Engine & Driveline Conversions
    Last Post: 19-03-2012, 05:30 PM
  3. X71 engine conversion
    Last Post: 20-09-2007, 05:45 PM
  4. MA70 --> JZA70 Conversion
  5. ra40 engine conversion?
    By noobra in forum Tech and Conversions
    Last Post: 26-11-2006, 02:16 PM
