Results 1 to 10 of 10
Thread: Thinking of a new fuel pump, which brand?
    Default Thinking of a new fuel pump, which brand?
    Hey guys,
    Doing some preventative maintenance and replacing the 21 year old fuel pump in the Camry.
    Repco's got a few on the shelf for $207, and have either a Bosch or a Fuelmeiser?
    Which is the better one to get or is there no real difference? Whats your experiences with standard replacement pumps.
    Thanks!
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Default Re: Thinking of a new fuel pump, which brand?
    if you can get one, try a 3sgte pump. does the job for me and the beams, so i'm sure it'd suffice for your needs too
    Direct swap too so no messing about
    Junior Member Backyard Mechanic KARNAGE's Avatar
    i have had good experiences with bosch i have never had one brake on me i have never used a fuelmeisser though so i cant comment on them. but i have used a couple of the bosch standard replacements and they worked fine.
    vic
    Just find an original denso pump from petrojet .
    Dave
    Quote Originally Posted by cambelt
    Dave
    The Egyptian company?
    Quote Originally Posted by KARNAGE
    Cheers for that!
    Quote Originally Posted by da_horse
    I'll keep that one in mind...i'd dare say they'd be harder to find. Any advantages using that one over the V6 one?
    Kind Regards,
    Kurt.
    vic
    If your car has had only clean fuel thru it the orig pump can do 50000klm klm .
    Ive cut open a few pumps at various hundreds of thousands of klm and they only sem to fail from dirty fuel seizing up the pump shaft .
    Dave
    ****** Grease Monkey
    W.A
    i'd go bosch, used in alot of cars, has a good rep.
    previous toyo's - 2 celica's, 5 soarer's, cressida, corolla, 3 supra's, 2 celsior's
    previous toyo engines - 18rc, 18rg, 7mgte x2, 1uzfe x5, 4agze, 1jzgte x2, 1ggte x2
    current toyo's- toyota supra jza80
    oregon
    try to size it for your need........ you don't need a 255 lph pump... all it'll do is cause problems(at the very least... fuel heating... at worst... could screw up idle and off idle performance)
    fuelmeiser arent as good as bosch. we get a fair few warranty claims on the fuelmeisers ( i work at repco).
    I'd go a bosch or preferably an original denso. Petrojet are on rooks rd nunawading.
    Quote Originally Posted by oldeskewltoy
    Yeah as i said, i'm not going for any high performance pumps, just a standard replacement pump. No need for anything better.
    Quote Originally Posted by Aust162
    Awesome. I'll call Petrojet and see what they can do for me, and if the price isn't good (ie. too high) then ill go for the Bosch.
    Cheers for the opinions!
    Kind Regards,
    Kurt.
  1. Picking Best Fuel Pump..!
    Last Post: 10-09-2007, 03:15 PM
  2. electric fuel pump for weber - which one?
    By slapper in forum Tech and Conversions
    Last Post: 01-03-2007, 07:09 AM
  3. trying to diagnose a fuel pump or FPR problem
    Last Post: 07-08-2006, 09:21 PM
