Results 1 to 14 of 14
Thread: 4age flywheel need help
    Junior Member 1st year Apprentice pen15's Avatar
    Jun 2008
    Default 4age flywheel need help
    hay evey1 i have a few questions on my 4age flywheel and toymods blokes know their stuff so here it goes
    1. i have got a lightened flywheel i believe from toda i baught it from Sprinterman68 i weighed it up on my precision scales and it came up as 5.5 kgs but want i want to know what it the weight of a standared 4age bigport flywheel
    2. 2nd question is how do i know the size of the clutch kit it uses i now the 4ages can have a 200mm clutch kit and a 215mm is this measurment taken from where the clutch plate bites the flywheel?
    Default Re: 4age flywheel need help
    1. probably around 9-10kg...
    2. yes. is there a raised area for the firction plate to rub against? the outer diameter of that
    Junior Member Backyard Mechanic gixer's Avatar
    That's not a Toda, Toda have the ring gear machined as part of the flywheel, Toda also weight less, 3.7kg for 200mm ultra light, 4.4kg for 212mm light weight.
    That almost looks like a home lightened?
    Whats with the small holes drilled in it?
    W.A.
    Quote Originally Posted by pen15
    1. My old AE82 4AGE Bigport flywheel weighs in at 8kg.
    2. The measurment is take from the outer of where the clutch plate contacts the flywheel. See pic of my lightened flywheel (4AGE AE82 Bigport 200mm)
    hope you have a scatter shield?
    why did you remove material from the area that needs most strength, and has least inertia?
    W.A.
    Dont panic! I didn't lighten it myself
    It's a Xtreme CNC machined chrome moly light-weight flywheel.
    oh, i got confused cos (i am tired and) you said "lightened" FW.. not light FW..
    still, i think they got it the wrong way around
    ie
    3.7kg
    4.4kg
    tho mine looks like this
    http://www.billzilla.org/alloyflywheel1.jpg
    Jun 2008
    thanks guys you know your shit well i would also like to know if 5.5kgs is an alright lighten up from standard and i have measured it to 215mm so should i get an exedy heavy duty 215mm clutch kit for a 4age cheers for the help
    Junior Member Backyard Mechanic KARNAGE's Avatar
    i might be wrong but im pretty sure you are looking for a 212mm clutch not a 215.
    ^^ it can be referred to as either. but yes the surface area is 212mm.
    mmmm... yummy 3.7kg Toda, i cant wait to put mine on.
    mmmm 2.8kg Toda (no.. not for 4A ) this will be interesting
    oregon
    Hmmmmm, from my info...
    Stock bluetop is 7.2 kilos... stock redtop and silvertop is 7 kilos... and stock blktop is 6 kilos. TRD is 5.5 kilos Toda, Jun are under 5 kilos
    Here is a photo of a stock blktop flywheel
    Jun 2008
    well 212mm clutch kit then i like the exedy kits so ill hook myself up unless you boys think there is something better for drifting but not heaps expensive cheers you have all been very helpful
  1. 3sge Beams in KE25 - Flywheel and Clutch
    Last Post: 15-08-2007, 10:43 PM
