Yes please, thanks!Originally Posted by Gimpster
I don't know how much it'll be higher, but I'm going to Bacci in Florence tomorrow morning with my g'box... so we will know soon the MINIMUM higher needed![]()
Originally Posted by jonathan yee
Yes, agree with both of you... and in fact the 6th gear ratio I used in the project is only a bit taller than stock.
This is the latest revision of the project... bit shorter 2nd gear, bit longer 5th gear:
Wolf_Tm (Parma;Italy) [Silat-Kali lover]
TM enduro 250cc 2stroke + Suzuki GSX-R 600 nakedized
Celica Gt-Four ST205 Snowy White [2.34kg/cv - 60.0Kgm @ 4957rpm]
http://www.facebook.com/wolf.tm - http://www.youtube.com/WolfTm250
Exactly!Originally Posted by wagonist
This is what we will try to do, so the 5th gear cover would be higher the minimum we can !
Originally Posted by Bill Strong
Unfortunately 400nm is way too low... personally I'm around 600nm now, but a slightly modded 3SGTE arrives too easily at that torque number...
but that is four cylinder torque right? rather peaky, not the same as a V6 or V8 flat torque curve. The transaxle is not under that amount of power for very long.
But it was just an idea.
The majority of the guys in the states have no clue what a custom gear set would cost them, and I would suspect that only a few would even consider it once the cost is made public.
This is not important, even if a 4 cylinder turbo engine has quite a wide torque... if a gearbox is rated for a torque limit, it doesn't care how the torque curve look like...
We will know soon the price... a C-one close ratio gearset costs around 2000$ if I remeber correctly:
this is another story, we are talking about a 6 speed conversion, so it should be more expensive.... but the fact is a Building for a Group Buy, will make it way cheaper for the factory AND for us... I hope...![]()
Cool. I'll watch this thread and keep the yanks updated since I sorta run the MR2OC
I am building a Rev2/3 hybrid ST165 GT4 so I would be interested as well.
Bill Strong
Racing Strong Motorsports
Home of the Worlds First V8 MR2
www.racingstrong.com ][ www.V8MR2.com ] [ www.mr2oc.com ]
thats a pretty healthy 3SGTE! with 2.2BAR or2.5BAR boost? has to be at least 2 BAR ....Originally Posted by Wolf_Tm250
doesn't 30psi make it a bit peaky?
Why do you think he wants closer ratios in the first place?Originally Posted by oldcorollas
i'm wondering what fuel....Originally Posted by web
Ah ah, wrong!Originally Posted by web
It'd be too easy to build an "high hp for 10 seconds", or an high torque@high rpm engine!
When i built it i looked only at increasing the area under the curve, keeping the max torque under 5000 rpm... so i don't absolutely have a peaky torque curve!
In fact you are right... personally i just need it only for the longer 1st gear i use in our mountains' roads hairpin turns!
OC, 30 psi with 101 ron pump gas...
that helps(btw, vid sounds good too
must be a very fat curve!
Thanks Mate!![]()
As I told you, this morning I went to Bacci's factory to take them my g'box and to talk about the project:
I'll have a reply in a week.
In the meanwhile, some pics of the factory, even if, for unknown reasons I deleted a photo of a fantastic full sequential 6spd box for a Delta Integrale Grp.A they were building... :
we have custom gear makers here in australia that we deal 2 of them via my work. one of them makes the 5 speed dog box for the WRC Corollas (based on GT4 cases with active centre diff). I have had that company make me custom gears & LSD centres before. The MINIMUM cost is usually A$1000 per pair of custom gears (like to moduify 5th on a stock box), and a full 5 speed dog engagment set with modiifed shafts, is typically A$7000-A$8000.
if this deal in italy falls over, I'll happily investigate here as I have the contacts and they already have patterns and intimate knowledge of this box.
I actually may be interested in that.Originally Posted by terryo
Since this thread has started, I've been noting at what speeds/revs I been using my box at normally. And crap its waaaaaay too low.
1st-2nd: 25km/h
2nd-3rd: 40km/h
3rd-4th: 55km/h
4th-5th: 70km/h
These are changing so that the higher gear comes in at 2000rpm, which on my engine it will pull quite happily to more than keep up with traffic.
The Vauxhall Cavalier NA 2.0L SOHC (Opel Vectra, or later model JE Camira for the Oz people's) I had when I was in Europe 3 years ago, I could only change into 4th at 70km/h, 5th at 95km/h to get 2000rpm in the upper gear.
It still had enough pull to drive well enough, but then averaged 7.5L/100km fuel economy while averaging 140km/h. Even overtook a Vtec Civic on the Nurburgringwhich the guy was well annoyed about when he found out the car had cost me €50!
I don't know if the GT4 guys have similar gearing to mine. Can anyone give me some feedback?
Maybe some of you guys have a peaky turbo which means your torque band starts higher in the rev range than mine, but personally I'd just be happier with a taller final drive so I can get fuel economy & be able to "stretch" each gear's use.
Off course, all of this may change after I get "decent" mountain road run in the Adelaide Hills on the weekend.
