Results 1 to 9 of 9
Thread: Retrofitting air con - tech sites and .. stuff
    Default Retrofitting air con - tech sites and .. stuff
    http://www.vintageair.com/catalog.asp
    lots of info regarding fitting aircon, and heater units etc etc..
    maybe not so useful for those with "new" cars that already have this techanology
    Achin' 4 some tyre bakin' Backyard Mechanic
    Default Re: Vintage Air- air con tech and .. stuff
    that gear has been around for like a thousand years, stu. so, what's better in japan today?
    Johnny Cash is my Navigator.
    corollamanic Backyard Mechanic
    May 2006
    does it mention anything about these???
    The vintage air guys make some really nice compact air systems. These are very commonly used in the US for muscle car builds etc. I haven't seen an Australian dealer for these yet but it would be interesting to see local pricing.
    they've been in the rod mags forever... fantastic solution for custom builds.
    http://www.vintageair.com/dealers_mf...ntry=AUSTRALIA
    Quote Originally Posted by AAAAGZE
    i don't have the skillz to handle that much old skool style!
    sorry Normy, i don't get any hot rod mags over here
    can you link up other sites with good tech? (i realise this site is pretty basic, but a good starter)
    Nov 2007
    I know a few good sites, but they aren't about Vintage air con.
    Default Re: Retrofitting air con - tech sites and .. stuff
    title changed for you.
    Nov 2007
    http://www.aa1car.com/library/retrofit.htm
    http://www.thirdgen.org/retrofitac
    Some Good Quotes from these sites.
    As it turns out, R-134a has a smaller molecular structure, and can seep out through older hoses. If your hoses are in bad shape, you might think about replacement, otherwise its not recommended as necessary. If it leaks out, it will be slowly, and an R-134a recharge is so cheap it’s not a big deal.
    The last thing you will need to do is adjust the clutch cycling switch. Located on the accumulator, the switch serves two functions: 1) it cycles the compressor on and off to prevent freeze up during use, and 2) it prevents the compressor from running if the pressure is too low. The switch needs to be set at 21 to 22 psi, to compensate for pressure differences of R-134a. The adjustment screw is located in between the two terminals on the end of the switch. It is typically set at 24-25psi with r-12, so ¼ turn of the switch counterclockwise should be -4 psi (1/4 turn = 4 psi).
  1. Tech nite - Fulcrum Suspension Tuesday 24 April 7pm
    Last Post: 27-04-2007, 04:13 PM
  2. Tech Tips
    By kingmick in forum Tech and Conversions
    Last Post: 11-06-2006, 07:31 PM
